Wobble - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 02-09-2019, 08:46 PM Thread Starter
tapcola's Avatar
Wobble
Ok , yes I have been over all the basics , geometry, new ball joints, Re tourque everything nothing seems to be lose . It just happened over night .
I have checked everything.
The one thing I found is my himes on my hydro are a bit lose. I will replace them . I am at loss maybe unit berings? They seem tight.
I dont know it was rock solid , yes I have rotated the tires .
SYNERGY, FOX,VKS,HUTCHINSON,
tapcola is offline
post #2 of 7 Old 02-09-2019, 10:05 PM
Dkjeep's Avatar
What kind / how old are the upper control arm joints on the axle side?
Dkjeep is offline
post #3 of 7 Old 02-10-2019, 07:16 AM Thread Starter
tapcola's Avatar
Synergy. 2yrs old .
tapcola is offline
post #4 of 7 Old 02-10-2019, 09:39 AM
rockystock's Avatar
Are you running the Synergy track bar frame bracket reinforcements?
If there's no usual suspects left to check, may want to check for maybe a hairline crack at the track bar bracket welds axle or frame
rockystock is offline
post #5 of 7 Old 02-10-2019, 10:41 AM Thread Starter
tapcola's Avatar
I have all new axle side brackets, but no I dont have the frame side .
tapcola is offline
post #6 of 7 Old 02-19-2019, 09:46 AM
elusive's Avatar
did you check the rear control arms? I had a bad wander and shake caused by the rear arms.
look for play in the joints. start with steering, then track bar, then control arms, then u joints, then ball joints. have someone saw the wheel while you look and feel for clunks .
elusive is offline
post #7 of 7 Old 02-19-2019, 04:06 PM
ndtguy's Avatar
Verify that your lug nuts are torqued to spec. That can cause a wobble if the lug nuts are coming loose.
NDTguy
2017 JKU Sport S
ndtguy is offline
Similar Threads
2014 Rubicon Newly Lifted with lower speed steering wobble, not death wobble kyleking777 Modified JK Tech Dept. 37 10-21-2016 08:09 PM
Wobble Wobble 45-50mph mschaffer66 Modified JK Tech Dept. 46 04-17-2014 01:29 PM
bump death wobble usmcdoc14 Modified JK Tech Dept. 24 06-08-2011 09:51 AM
Death Wobble DC1Gary JK General Discussion 39 06-05-2008 10:43 AM
Why am I getting a death wobble? C-rog Modified JK Tech Dept. 29 03-30-2008 12:08 AM
