Is. 2.0 front coil over enough shock for a 2door - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By thedirtman
post #1 of 7 Old 02-04-2019, 08:13 PM Thread Starter
Is a 2 inch coil over enough shock for a little go fast as well as rock crawling? I have a 2door with an 8inch stretch 60s. The coil over kit I have only excepts 2 inch coil overs.
Just looking for some feed back before I install
qwest4air is offline
post #2 of 7 Old 02-04-2019, 09:34 PM
yes they work fine
post #3 of 7 Old 02-05-2019, 07:49 AM
ALASHA's Avatar
Im actually a little surprised @thedirtman didnt ask for some more specifics.
How much "go fast" are you doing and how aggressive?
What Coilover kit is this? Im wondering how they are mounted.
ALASHA is offline
post #4 of 7 Old 02-05-2019, 09:09 AM
Most people run too long a travel shock for go fast and put the mounts in questionable locations. They also don't run the right coils or a decent amount of preload. Lots of factors go into it. I am just getting tired of doing the same thread over and over, I guess i was having a bad day yesterday and just didn't care to ask any more questions as most people asking want justification to run something they really don't need.
ChuckTheRipper likes this.
post #5 of 7 Old 02-05-2019, 01:08 PM
ALASHA's Avatar
What is too long a travel shock for go fast? You mean its outside the range of the driveshaft?
ALASHA is offline
post #6 of 7 Old 02-05-2019, 01:18 PM
No, they will run too little up travel in their set up. You mainly see a coil over set up LCOG with around 4" of up travel and 8" of down. This is just not enough up travel for go fast to work without constantly bottoming out.
post #7 of 7 Old 02-05-2019, 01:22 PM
ALASHA's Avatar
Gotcha. So its not too long of a shock per se. Its just too long for how much up travel you are setting it up for.
ALASHA is offline
Similar Threads
ADJUSTABLE WELD ON FRAME COIL OVER/AIR SHOCK MOUNT TOWERS kmd Garage Vendor's Marketplace 13 01-08-2014 11:56 AM
2" lift Coil Springs for 2door Jeep JK - Old Man Emu techpimp For Sale 8 12-29-2011 09:06 PM
Enough shock travel with Mopar 2" and Rubicon Express 1.75 spacers Hardcoreheath Modified JK Tech Dept. 1 07-15-2010 11:15 PM
Alpha-1 Front coil over kit ordered! FUN LS1 JK General Discussion 4 10-08-2009 08:03 PM
Enough Is Enough:Airpark Jeep Signs Up Officially On JKO jdemonto Vendor's Marketplace 14 03-21-2009 09:15 AM
