Limit Straps - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 02-02-2019, 03:52 PM Thread Starter
Limit Straps
I'm installing King 2.5 smoothies on my rig. Should I install limit straps? We offroad 4-5 times a year and usually just do dirt/rock trails, rock gardens, rock ledges, etc. We rarely go fast offroad. I will open it up a little on the sand when we go to Attica Indiana (Badlands Offroad Park) but I can't see it getting any "air" ever. So about the only time I would ever have the shock fully extend would be when rock crawling which would be slow speeds. Are the shocks hurt at all fully extended at slow speeds? Or no speed at all? Please explain. Thanks
Quick edit - one ton axles and 40" Toyos
18 JKU Granite Crystal- 4"lift, 40s, UD60s
07 Red Rock Crystal JKU - Sold
RedRock0740 is offline
post #2 of 7 Old 02-02-2019, 06:09 PM
It's funny you ask this because , for me it's coincidental in that
I actually read this last week & had it in my browser history , heh . It did a satisfactory job of explaining the limit strap &
if it would benefit my setup . Maybe it'll do the same for you :
Limit Straps Why Your 4x4 Suspension Will Benefit: Off-Road.com
post #3 of 7 Old 02-03-2019, 06:05 AM
Plenty of people (probably 99% of JK's don't have limit straps) get tires in the air at the trail with no limit straps and have no problems. This is more or less evidence that you probably won't have problems rock crawling without limit straps. If I put in high-value shocks, I'd probably put in limit straps anyways just to protect the investment. If I were running generic lift kit $50 shocks I probably wouldn't bother for low-speed extension.
If you're "opening up a little" on the sand means on whoops etc., then you can have violent extension events even if you're not really getting air in the traditional sense of jumping. Even though a tire is touching the ground or perhaps an inch or two off the ground, it might as well be getting air from a force standpoint, there's no weight on the spring and the shock is extended. Anything like that I'd for sure put on limit straps or it's a recipe for disaster on the shocks.
christensent is offline
post #4 of 7 Old 02-03-2019, 07:45 AM
^this .
@christensent has it pretty-much spot-on in that comment.
post #5 of 7 Old 02-03-2019, 06:44 PM Thread Starter
Thanks guys. That's pretty much what I was thinking also. I've ran without straps for the last 8 years with TF and Bilstein shocks. No big deal. But, with what I have invested now, I think I will add the straps. I usually don't do the whoops, but you never know. Now that I have good shocks maybe I'll like them better (whoops). I'm still running extended factory style bumps, so I will still have to be a little careful. I'll add them. Thanks again.
post #6 of 7 Old 02-05-2019, 06:28 AM Thread Starter
What brand straps are you guys using? Most brands claim to figure in 1" of stretch. There is one company (ORW) that claims 1/4" stretch. This is hard to believe when most all others claim 1", but they are claiming that it's a quad strap so less stretch. Also, I've seen some adjustable clevises out there. Are these worth it or not?
post #7 of 7 Old 02-05-2019, 07:46 AM
The adjustable clevis makes it nice to adjust instead of having to change out the mounts and is easy to weld to the side of the frame.As far as brand it is up to you and your budget. I would not put too much thought into brands of limit straps on a JK. I get mine from trail ready since I can pick them up at my local summit racing store.
Similar Threads
center mount limit straps desert dog Write Up Dept. (The Library) 22 12-22-2012 03:00 PM
Limit Straps Length e-jeep Modified JK Tech Dept. 2 05-04-2011 08:54 PM
FOR SALE 20" PROCOMP LIMIT STRAPS [email protected] For Sale 0 03-28-2011 02:32 PM
limit straps vwang Modified JK Tech Dept. 7 02-14-2011 04:38 PM
Limit Straps... STUPIDFACE Modified JK Tech Dept. 18 12-21-2010 09:38 PM
