Bent LCA mount - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By hokiewest
post #1 of 5 Old 12-31-2018, 01:10 PM Thread Starter
FutureJK's Avatar
Bent LCA mount
Rear passenger side LCA axle side mount is bent in pretty far...the arm was bent too and I’m replacing it with another stock arm for now until I upgrade arms. While I have the arm out I was thinking about heating the bracket up and bending it back. It rubs the arm during articulation. Or I suppose I could just cut the bent portion off. Is either option a bad idea?
2012 JKUR, 2.5" RK Flex, 35" Falken MTs, VKS Sliders, PSC Fenders and Tire Carrier, Crawler Conceptz Skinny Rear Bumper, Amazon Cheap-o Special Front Bumper
FutureJK is offline
post #2 of 5 Old 12-31-2018, 02:13 PM
hokiewest's Avatar
Oh thatís nice! Have you tried bending it with a pipe wrench, large adjustable crescent or vice grips? Some leverage and it should go, put the bolt back in too (with a thick washer if ya got it) so it wonít deform (widen) the bracket as much. Itís going to be fatigued no matter what so not as strong as it was before...but hey that just means itíll bend back easier next time
rich6700 likes this.
hokiewest is offline
post #3 of 5 Old 01-01-2019, 02:35 PM
gt1guy's Avatar
You wont need to use heat to bend factory brackets.
Kevin
gt1guy is offline
post #4 of 5 Old 01-01-2019, 03:08 PM
Yeah you won't need any heat to straighten it up , but it wouldn't hurt to look in the Artec catalog for a couple of LCA bracket skids , you pretty much beat that one repeatedly .
un lupus is offline
post #5 of 5 Old 01-30-2019, 03:59 PM
RedRock4wd's Avatar
I agree with using skids.
I had smashed my Front LCA brackets pretty bad, so during install of front skid plates I realized how much I actually had moved them.
It will help keep the brackets from folding back together again, and keep from the LCA's from binding on the mounts.
Sales Manager - Red Rock Offroad
2008 JKU Rubicon - 3.5" Pro-Comp Lift on 37" Toyo MT's
Contact Red Rock 4wd at
RedRock4wd is offline
