Ball joint dilemma - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By rich6700
post #1 of 13 Old 12-29-2018, 04:08 AM Thread Starter
Ball joint dilemma
Hi, trying to replace my upper ball joint and been unsuccessful in getting one that fits. All the new BJ are loose in the axle housing.
Tried omix and teraflex knurled... the omix and old ball joint are side by side in this pic. There seems to be no oem taper on the old BJ. The teraflex still popped out as it seems not enough knurling seats before it tapers off like OEM.
Had a shop install bj about 3 years ago (now closed... thought they were synergy BJ) anyone else had this issue and how did they solve it? If I only could find out the old BJ to be able to replace🏻
rubirn is offline
post #2 of 13 Old 12-29-2018, 04:19 AM Thread Starter
Here is the photo-
rubirn is offline
post #3 of 13 Old 12-29-2018, 05:05 PM
Originally Posted by rubirn View Post
Here is the photo-
I'd put calipers on them and the hole and see what the difference is.
wvjeepguy81 is offline
post #4 of 13 Old 12-29-2018, 05:06 PM
hokiewest's Avatar
Will need to use knurled joints again since the old ones were knurled BJs. Surprising the knurled TF ball joints arenít a press fit, but have never dealt with them so not sure how they compare in diameter. Might be best to try Synergy BJs since they are known to be a very tight fit and you think they may be the old ones.
hokiewest is offline
post #5 of 13 Old 12-29-2018, 05:41 PM
rich6700's Avatar
Once you use knurled ball joints you'll have to stick with using them. Knurled ball joints are slightly bigger than the smooth ones.
dahreno likes this.
rich6700 is offline
post #6 of 13 Old 12-30-2018, 03:39 AM
DJ1
DJ1's Avatar
They might be MOOG ball joints...
---> https://www.moog-suspension-parts.co...angler_jk_2012
DJ1 is offline
post #7 of 13 Old 12-30-2018, 07:44 AM Thread Starter
I did try the teraflex knurled BJ... it pressed in but didn’t hold. The knurling on the teraflex only went to where the taper starts on the BJ- hence only pressing in about half way because it tapers.
The old BJ doesn’t even have that OEM taper it seems straight in the picture.
I hope the shop wouldn’t have bore it out the taper to fit that straight looking BJ?
rubirn is offline
post #8 of 13 Old 12-30-2018, 11:15 AM
rich6700's Avatar
I'm having a hard time trying to understand your problem. Dana 30 and dana 44 ball joints have been the same size for over 30 years. The knurled joints where used when the smooth sided joints wore out the outer "c" because they are slightly larger. Take a pic of the joint in the outer. "C" or a short video.
rich6700 is offline
post #9 of 13 Old 12-30-2018, 11:47 AM Thread Starter
I’ll take a pic of the c after the holiday... what I can tell is the old ball joint is straight and has no taper. I can press down the teraflex knurled(not pictured) but the taper on it like the oem doesn’t press into anything. Seems the hole in the c is longer to accept this straight no taper ball joint?
rubirn is offline
post #10 of 13 Old 12-31-2018, 02:58 PM
The taper on the pictured right side Ball joint is there to help guide it into the hole straight and center it as it is pressed in.....The taper you need to concern about is the taper on the shaft, that it is correct for your application.
Tspevacek is offline
post #11 of 13 Old 02-24-2019, 10:19 AM
Pmedic920's Avatar
Bump.
Any updates?
Iím in the beginning stages of preparing to replace my BJs, and Iím curious of what your outcome was.
Iím no expert but it seems too me that the last shop must have done something thatís causing the correct BJs to not fit correctly.
In my case, I plan to keep my Jeep forever, Iíd probably replace/upgrade my knuckles, that way Iíd have a sure fit moving forward.
BJs are a fairly frequent wear replace item, and Iíd hate to not have a good fit every time.
Pmedic920 is offline
post #12 of 13 Old 02-24-2019, 10:32 PM
Does sound like they reamed out the hole. May have to replace the knuckle. Is it just one side or both sides
libordemise is offline
post #13 of 13 Old 02-25-2019, 08:37 AM
Originally Posted by Pmedic920 View Post
Bump.
Any updates?
if you are going to keep your Jeep a long time, go Rare Parts ball joints. expensive upfront but they are running strong. the Dynatracs don't really last any longer than the others yet the rebuilt kit is stupid expensive.
2017 JKUR Recon 6spd Firecracker Red
SecTxAg06 is offline
