Pulling apart transfer case - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 12-24-2018, 04:57 PM Thread Starter
TRAUMAhead's Avatar
Currently rebuilding the transfer case and having trouble pulling it apart. On older cases there was a notch on the seam where you could using a screw driver. With the 241 case it has 3 spots with ledges and I can't seem to find a away to pull it apart. Any advice?
TRAUMAhead is offline
post #2 of 9 Old 12-24-2018, 05:53 PM
ronjenx's Avatar
Maybe a bar clamp, reversed so it spreads as you squeeze the trigger?
ronjenx is online now
post #3 of 9 Old 12-24-2018, 09:29 PM
rich6700's Avatar
I usually use a mallet and neat it apart.
rich6700 is offline
post #4 of 9 Old 12-24-2018, 11:41 PM
rockystock's Avatar
I think I used a pry bar with a couple small pieces of wood to protect those lugs.
rockystock is offline
post #5 of 9 Old 12-25-2018, 07:56 AM
4wheels4life's Avatar
Put a nut and bolt in between those lugs and loosen the nut and bolt. Acts like a spreader.
2007 JKU X, 6.0 ls and 6L80e, 4.10, 4" ProComp Stage 1 lift, AEV drop brackets, 315/70R17 Milestar Patagonia MT , Vision Nemesis 111, 17X9 wheels
4wheels4life is offline
post #6 of 9 Old 12-26-2018, 01:36 AM Thread Starter
TRAUMAhead's Avatar
Mallet worked.
Found out the seal that goes inside the input shaft to the transmission was at an angle/not seated properly which caused the transfer case to leak oil into the transmission. I don't see how that could've happened.
post #7 of 9 Old 12-26-2018, 05:23 AM
Originally Posted by TRAUMAhead View Post
Mallet worked.
that IS a little odd. Has it always leaked since you have had it or recently started?
I'd want to know if it was some driving/off-road scenario that contributed to it or if it was an original assembly oversight...
I suppose if your running an automatic slushbox , it wouldn't hurt the tranny since it calls for same ATF+4 as xfer case but that's still 1st I've ever heard of that.
Glad you sorted it out.
post #8 of 9 Old 12-26-2018, 11:14 AM Thread Starter
TRAUMAhead's Avatar
When I've had it serviced they had to top it off sometimes but I didn't think much of it so it's probably been like that since the beginning. It wasn't until recently after I added fluid to the transfer case the transmission was overfilled that I put the two together.
post #9 of 9 Old 12-26-2018, 03:42 PM
Understood.
