UD60: ARB or E-locker?? - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By un lupus
post #1 of 14 Old 10-17-2018, 03:57 PM Thread Starter
toymaster's Avatar
I'm been off the Jeep forums for a while and do not know the latest reports. Are people getting better results with the Ultimate Dana 60 with the ARB or E-locker option?? I'm close to ordering and wanted to feel the pulse of the enthusiast crowd.
JK 2dr rubi
toymaster is offline
post #2 of 14 Old 10-17-2018, 08:48 PM
ARB is far stronger...air lines are more prone to leaks/holes
1997 TJ --SOLD
1999 TJ --SOLD
2001 TJ --SOLD
2007 JK Unlmited Rubicon --SOLD
2013 JKUR Billet Silver-- SOLD
2016 JKUR White --
Marine01 is offline
post #3 of 14 Old 10-18-2018, 07:53 AM
ALASHA's Avatar
I believe the UD60 still use the 2 pin design. I have them in my JK and havent had any issues with the lockers. Dont need a compressor, air lines or solenoids (which are prone to crapping out)
ALASHA is offline
post #4 of 14 Old 10-18-2018, 09:41 AM Thread Starter
toymaster's Avatar
I'm aware of the external needs, pros/cons, of each design. I'm more interested in the robustness of the internal design. In short, if i'm dropping $12K on axles I want a no hassle deal. (here is my money, can I go play now, type deal)
I assume the design of the E-locker is the same as my Rubicon 44's, If I'm wrong here please correct me. And, i'm not overly impressed by the weak magnet design. I have my rear axle apart right now and am replacing the actuator. I tried the taking apart, polishing and shimming thing with very little positive results.
I'm trying to determine which option is the best probability of buy, install, and forget it. As Forrest Gump says "one less thing in life to worry about" would be my happy ending.
JK 2dr rubi
post #5 of 14 Old 10-18-2018, 11:05 AM
The E-locker in the 60 configuration is way more robust than the 44 is just in relation to the size alone , I went with them in my Fusion axels , but I have the ARB's in my CJ and really don't find them to be a "pain in the ass " as so many folks tend to describe them , just drain the water from the air tank once in a while that's it .
Air lines properly installed and routed are a non-issue as well , all the people that complain about failures such as ripping them off will experience the same condition with the E-locker getting ripped off as well . So that is also a false concern too .
The only thing I like a little more is I can hear the ARB click at engagement and the E-locker is silent but that's it .
It really boils down to which one do you feel more comfortable with , personally I like the ARB for the ease if repair and ability to diagnose a problem than E-locker , you can see the function of the air .
un lupus is offline
post #6 of 14 Old 10-18-2018, 10:32 PM
DJ1
DJ1's Avatar
ARB also makes a much beefier air line if you feel their standard blue line isn't up to par.
I haven't bothered to install it yet since the blue line has been doing fine on my front locker. It is easily the same diameter of some of the lines I have sitting here for hydro assist. It is definitely beefy.
DJ1 is offline
post #7 of 14 Old 10-19-2018, 07:50 AM
Crown Performance also makes lines for the air lines too , I like them, they have reinforcement at the ends to enhance wear resistance from the area that sees the most movement .
DJ1 likes this.
un lupus is offline
post #8 of 14 Old 10-19-2018, 08:39 PM
SLO
I was wondering the same and NR4X4 tends to recommend the E-lockers in the UD60’s specifically. I guess they have been seeing some issues with ARB in the Ultimates. I don’t know details but it may be worthwhile calling them. I’m going E-lockers in Fusion 60’s just so I’m not relying on onboard air and worrying about air lines. I know many do it without issues but I don’t feel like dealing with it.
SLO is offline
post #9 of 14 Old 10-20-2018, 12:57 PM
spinuck's Avatar
I went with e-lockers in both my prorocks and ud60s for the reasons mentioned above. The ud60 locker is different than the rubi one. Only issue we've had with the ud60 one was that it didn't unlock when my wife broke the rear drive shaft on Metal Masher. The think the jolt bound it up. It took a hammer and punch on one of the "ramps" to turn it where the pins would release. It was a case of too much throttle i believe not so much a problem or defect in the locker.
spinuck is offline
post #10 of 14 Old 10-27-2018, 11:09 AM
Dzldust's Avatar
Personally I have the E-lockers in my UD60’s with 40’s with zero issues,have a buddy running same setup on 45” swappers and he beats it “Hard” and has yet to have a breakage or any issues .
2012 Jkur
UD60’s 5.38’s E-lockers
3.5” RK coils
40” Coopers/DirtyLife BL’s
Rusty’s Long arms
AntIRocks
B.Lees steering
PSC/RNR Steering
Evo/UCF armor
Dzldust is offline
post #11 of 14 Old 10-28-2018, 08:34 AM
What is your definition of “hard”? I’ve already broke the 2 pin rear locker and replaced it with a 4 pin on 40” cooper tires.
Redrockjeepin is offline
post #12 of 14 Old 10-29-2018, 07:29 AM
I went with the Eaton E Locker when I had my PR44. I found it was stronger and engaged faster than the Rubicon E Locker. I never had a problem with either one. I would always slide the Jeep into neutral for a couple seconds when engaging them so there was no load on the driveline.
scubatech is offline
post #13 of 14 Old 10-29-2018, 07:49 AM
ALASHA's Avatar
What were you doing?
ALASHA is offline
post #14 of 14 Old 10-29-2018, 10:51 AM
Crawling rocks/trying to climb a 6 foot ledge. I upgraded to the 4 pin elocker and haven’t had any issues since then except spinning one of the front tubes
