Onboard Air Options with LS - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By gt1guy
post #1 of 16 Old 10-16-2018, 10:03 PM Thread Starter
SLO
Are there any good locations for onboard air in the engine bay with the LS or do I need to start considering options in the cabin?
SLO is offline
post #2 of 16 Old 10-17-2018, 07:03 AM
you could do a York compressor.
https://jeepspeedshop.com/product/yo...et-ls-engines/
https://www.littleshopmfg.com/gm-4-8...ompressor-kit/
post #3 of 16 Old 10-17-2018, 08:26 AM
ALASHA's Avatar
Goatbuilt also makes a Yokr LS bracket:
https://goatbuilt.com/product/gm-ls-...assenger-side/
If you are going this route, do some research to make sure these will have enough clearance and they are the right offset for your belt drive system.
ALASHA is offline
post #4 of 16 Old 10-17-2018, 11:23 PM Thread Starter
SLO
Thanks guys. So, it sounds like I either mount something like the ARB twin under a front seat or go with one of the York kits?
SLO is offline
post #5 of 16 Old 10-18-2018, 06:33 AM
Or you could try mounting a viair behind the passenger tail light. I saw someone did it a few years back. I tried and couldn't get it to fit in there.
post #6 of 16 Old 10-18-2018, 07:52 AM
ALASHA's Avatar
You have several options.
You can go with a belt driven York with one of the brackets mentioned. This is one of your highest flowing options since it will pump a lot more air than almost any electric compressor.
You can go with an ARB twin. I swear there is a way to still mount it under the hood with an LS. Keith B. on here made a custom bracket to mount it over the engine:
https://www.jkowners.com/forum/elect...er-engine.html
You can mount the ARB twin under the seat.
You can try to sneak a VAIR behind the tail light like Uncle Sams Misguided Child suggested.
You can put a VAIR in the trunk compartment although I am not a huge fan of this one since those get hot and that is a contained area.
You can make a bracket somewhere in the trunk area and mount any compressor you want.
You can try to find the WARN winch with integrated compressor (although its no longer on their website).
You can run CO2.
You can buy an Oasis and have it take up half your trunk.
ALASHA is offline
post #7 of 16 Old 10-19-2018, 08:32 PM Thread Starter
SLO
Thanks ALASHA. Really comprehensive list. I think I like the York route the best. Although, since I’m going with e-lockers in my Dana 60’s, I’m even considering just getting 2 of the $50 compressors off Amazon and running them off a quick disconnect off the battery. For $100, I’m airing up two tires at a time.
SLO is offline
post #8 of 16 Old 10-22-2018, 08:04 AM
ALASHA's Avatar
Thanks ALASHA. Really comprehensive list. I think I like the York route the best. Although, since Iím going with e-lockers in my Dana 60ís, Iím even considering just getting 2 of the $50 compressors off Amazon and running them off a quick disconnect off the battery. For $100, Iím airing up two tires at a time.
There are kits out there (cant remember the brand at the moment) that will allow you to fill all 4 tires at the same time and have a bleed valve or something to notify you when you have reached your desired psi.
As for the electric compressors, what size tire are you running and what psi do you plan to air them up. A York flows significantly more air than those little compressors so think about how much time you want to spend waiting vs. how much you want to spend.
For me, I hate waiting so the York is awesome and the Oasis should be even better. The York take my 40" tire from 10 to 30 psi is roughly 1 minute 15 seconds if I remember right.
ALASHA is offline
post #9 of 16 Old 10-23-2018, 05:39 AM
KOWBOY's Avatar
The York compressor's the best way to go for sure as far as high volume air. Can easily run impact guns off it. Gotta make sure ya keep oil in it though or they'll burn up after a while. And make damned sure ya get the belt routed correctly. Previous owner of the Turd had a bullshit kit from Nemesis to mount one on the hemi. Totally fucked up design.
So we then went with the twin ARB instead. Which is a suitable replacement in my opinion but definitely ain't got the balls of a York. Had it under the passenger seat for awhile but got tired of listenin' to it and it wouldn't fit no more anyhow once we lowered the seats for more headroom. So put the stereo amp under there instead and moved the ARB compressor under the hood. I like that better. It's also hooked to one of them deals Alasha's talkin' 'bout where you pipe the air down the frame rails and then hook all 4 tires into the system at once. It's a pretty damned convenient to let the system do all the work of airin' up or down while ya stand there and drink Coors.
My Trailer Queen don't ride on one ... it pulls one.
KOWBOY is offline
post #10 of 16 Old 10-23-2018, 08:13 AM
ALASHA's Avatar
For reference, found one of them fancy systems I mentioned:
https://updownair.com/product-catego...ation-systems/
ALASHA is offline
post #11 of 16 Old 12-29-2018, 09:59 AM Thread Starter
SLO
That’s a really cool system. JK Innovations makes one as well. I ended up going with a Power Tank. I like the idea of the Monster Valves paired with the tank. I don’t have my Jeep back yet but my understanding is that you can air up and down in less that 30 seconds.
SLO is offline
post #12 of 16 Old 12-29-2018, 11:44 AM
White13JKUR's Avatar
Thatís a really cool system. JK Innovations makes one as well. I ended up going with a Power Tank. I like the idea of the Monster Valves paired with the tank. I donít have my Jeep back yet but my understanding is that you can air up and down in less that 30 seconds.
Sorry for not chiming in earlier. I've been running the ARB twin under the passenger seat for a while now and like that.
I made my own 4 tire inflation doomaflatchi and posted about it here....
https://www.jkowners.com/forum/write...-deflator.html
It works well.
White13JKUR is offline
post #13 of 16 Old 12-30-2018, 09:24 AM Thread Starter
SLO
It works well.
What a cool idea. I like the inline pressure gauge. I actually found some sites that sell the thin poly air line line the JK Innovations kit uses. It rolls up much more compact.
I may put the ARB twin compressor under the seat as a backup to the Power Tank. Is there any reason it couldn’t go under the driver seat?
SLO is offline
post #14 of 16 Old 12-30-2018, 09:27 AM
Is there any reason it couldnít go under the driver seat?
The lengths of 8ga wiring to the battery is just right when the compressor is under the passenger seat.
post #15 of 16 Old 12-30-2018, 05:27 PM Thread Starter
SLO
Got it. That makes sense. I still haven’t found where the access is in the firewall on the passenger side. I’d re-wire everything if I could find it but right now, everything is going through the access hole on the driver side but it has to traverse back to the battery. Lots of extra wire.
SLO is offline
post #16 of 16 Old 12-31-2018, 12:35 PM
gt1guy's Avatar
Got it. That makes sense. I still havenít found where the access is in the firewall on the passenger side. Iíd re-wire everything if I could find it but right now, everything is going through the access hole on the driver side but it has to traverse back to the battery. Lots of extra wire.
See the gigantic hole on the passenger side.
That's where the main wiring bundle goes through. Should be able to finagle a wire through there.
ChuckTheRipper likes this.
Kevin
gt1guy is offline
