Genright 25gal has tank - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 09-08-2018, 10:24 PM Thread Starter
Rubicrawlin's Avatar
Has anybody installed the GenRight tank with the Synergy Rear Shock relocation brackets? I have the brackets already and they are welded in place. We want to put in a new tank in the rear but I am not sure it will clear with the mounts.
Sent from my iPhone using Tapatalk Pro
Rubicrawlin is offline
post #2 of 4 Old 09-08-2018, 10:27 PM Thread Starter
Sorry for the misspell. GenRight Gas tank is what I meant.
post #3 of 4 Old 09-09-2018, 11:12 AM
I've got the 20gal but same clearance issues I would think.
Couple of things I would do:
Remove their small fill tube and weld in a 1.5" or larger OD.
Its not going to be a legal swap anyway so just well get fuel in easier
I didn't think of it untill after I filled it with 10gal of fuel, may redo it later.
Second get rid of the small vents and go to 1/2", same reason faster fuel fill.
You can get them from:
https://www.breezeautomotive.com/sho...eck-valve-kit/
CT Performance, Inc is offline
post #4 of 4 Old 09-09-2018, 10:00 PM Thread Starter
Thank you for the heads up and suggestions. I will look into this.
