Misfire - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By j3ff3ry_j33p
post #1 of 6 Old 08-26-2018, 11:04 AM Thread Starter
jtlr's Avatar
Misfire
2013 with about 80km(50k miles) started to misfire while under load only when warm.
No codes are recalled with my flashcal
Any ideas?
2013 Sport
Stretched F+R
Coilovers F+R
Built and locked 44s F+R
40x13.5 Maxxis RAZR
Full skids
jtlr is offline
post #2 of 6 Old 08-27-2018, 05:44 AM
Any ideas?
maybe not the culprit but I recommend starting with where I have learned to for ignition stumbles or misfires on the JKs:
i always start misfire diagnostics by the checking for arc to engine or block in the dark while it is running due to pinhole developing in the gray boot on the sparkplug wires. If you run engine in dark and open hood with absolutely no light present , you'll see the blue arc(s) if this is occuring.
I have had it twice.
I run heatshield boots on the plug wires & since doing so , have nver had it again.
3.8l 2011 JKU
post #3 of 6 Old 08-30-2018, 10:53 PM
Rb6700's Avatar
3.8l 2011 JKU
No plug wires on the 3.6l
Rb6700 is offline
post #4 of 6 Old 08-30-2018, 11:00 PM
Rb6700's Avatar
Only when warm to me will indicate a coil pack shorting out. Your going to have to have it checked out with a real scanner to find which coil pack is having an issue. My advice to you is if it's one of the coils on the drivers side of the engine change all the spark plugs while it's apart since the upper intake manifold has to come off.
Rb6700 is offline
post #5 of 6 Old 08-31-2018, 04:21 PM
looks like I'm either slowin' down as I get older or I'm just failing to read , heh.
my bad.
Rb6700 likes this.
post #6 of 6 Old 09-04-2018, 12:27 PM Thread Starter
jtlr's Avatar
Actually got lucky!! it was the cylinder 3 coil pack!!
Thanks for the help guys!!!
2013 Sport
Stretched F+R
Coilovers F+R
40x13.5 Maxxis RAZR
Full skids
jtlr is offline
