2018 Auto JK - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By j3ff3ry_j33p
post #1 of 5 Old 08-15-2018, 03:55 PM Thread Starter
2018 Auto JK
Curious to hear people's thoughts on this. How many of you have installed a trans cooler? We do a lot of wooded trail wheeling where it can get pretty slow at times with summer heat. So thoughts on this please.
Also, I'm running a Redneck Ram and tapped factory steering gear (from my 2007JK). At the moment I'm just running the factory reservoir. I have a PSC enlarged aluminum reservoir that I ran on my 07. Will it help at all to use the PSC over the stock reservoir? Also, should I install an inline cooler for the steering assist. I didn't have any issues on my 07 and I never installed a cooler.
My 07 was a stick, so the auto JK is new to me. I just don't want to hurt the trans or the steering pump. My new JK is a 2018 JKU (not a JL).
18 JKU Granite Crystal- 4"lift, 40s, UD60s
07 Red Rock Crystal JKU - Sold
RedRock0740 is offline
post #2 of 5 Old 08-15-2018, 04:13 PM
ronjenx's Avatar
Your 2018 Auto JK has a transmission cooler. It's mounted behind the grill, in front of the A/C condenser.
ronjenx is offline
post #3 of 5 Old 08-16-2018, 05:42 AM
why would you not run a cooler for the power steering? They don't cost that much considering how much of an investment you already have in it.
post #4 of 5 Old 08-16-2018, 05:47 AM
^X2 ?
of coarse, run a cooler for it.
Run a cooler for anything you can if you think heat might be an issue.
I run a large GVW aux transmission cooler ( plate style) for my 42RLE. It works splendidly and I have a black '11 which sits in the deep, Southern sun idling for looooong periods of time, then driving super slowly , mostly on hot slabs of Tennessee or Alabama limestone. Coolers are our friends.
re: the resi, the more fluid you can move thru the steering the better response from the actual steering.
post #5 of 5 Old 08-16-2018, 05:50 PM
Mason's Avatar
You might as well add a filter to the power steering system. It will add some more fluid, and it will also clean the fluid which will make everything happy.
Mason is offline
