JK -07 alignment results - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 07-05-2018, 03:44 AM Thread Starter
As the Wrangler is not a common car here in Finland, I typically have to read a lot about whatever I'm planning on doing to my rig before I take it to the shop. I recently installed OME 2 inch spring lift with OME shocks and steering stabilizer. I'm running on 285/70/17 tires. In Finland it is a must to have a vehicle inspected and approved after a lift installation and vehicle alignment report is needed for the approval. I got my Jeep aligned recently and would appreciate if any of you could give some comments on the results. As such, the report is OK because it shows that readings are within specs (meaning I won't have troubles when getting the approval). My main concern is, however, that the original specifications seems to be different regarding JK alignment specs I have seen on several Jeep forums. Also, I would like to know if there is something else that you could point out from these values.
The final results were:
FRONT LEFT
Caster 2.35 (specs range 2.20 - 4.30)
Camber -0.06 (-1.3 - -0.05)
Toe 0.7mm (0.5mm - 0.8mm)
FRONT RIGHT
Caster 2.28 (2.20 - 4.30)
Camber -1.28 (-1.3 - -0.05)
Total toe 1.4 (1.0mm - 1.6mm)
REAR LEFT
Camber -0.41 (-0.45 - 0.00)
Toe -0.1mm (-0.4mm - 1.5mm)
REAR RIGHT
Camber -0.19mm (-0.4mm - 1.5mm)
Toe 1.1mm (-0.4mm - 1.5mm)
Total Toe 1.0 (-0.8 - 3.0)
Thrust Angle 0.06 (-0.15 - 0.15)
Other measurements:
SAI left 12.19
SAI right 13.54
Included Angle Left 12.13
Included Angle Right 13.54
Setback Front 1mm
Setback Rear -6mm
Track Width Diff. 0mm
Wheel Base Diff. 6mm
Front Ride Height Left 500mm (488mm - 512mm)
Front Ride Height Right 500mm (488mm - 512mm)
Rear Ride Height Left 505mm (494mm - 517mm)
Rear Ride Height Right 505mm (494mm - 517mm)
Many thanks to anyone capable commenting or pointing out if there is something I should take care of.
anttik is offline
post #2 of 2 Old 07-06-2018, 10:33 PM
ockgator's Avatar
With 2" lift I would get the caster closer to the 4.3 degree max, Don't know if they allow "custom" settings there. This can be done with either cam bolts on the lower control arms (axle end of arm), Control arm drop brackets or adjustable control arms.
Proud to be deplorable
ockgator is offline
