Rear brake lines 2 door - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 07-04-2018, 09:23 PM Thread Starter
jkwebbie's Avatar
Looking for some help from guys that have stretched their 2 doors. My build is almost done but I need help with brakes. Since I'm stretched about 8 or so inches in the rear, I need some ideas on how you guys ran your brake lines. I'm wanting to run the lines down my upper links and then out to the calipers once the lines reach the axle. If any of you have done this can you post some pics, and hopefully part numbers, to help me get the ball rolling. I'm running a triangulated 4 link in the back. Thanks
Sent from my SM-G935U using Tapatalk
jkwebbie is offline
post #2 of 3 Old 07-05-2018, 06:51 AM
Run them just like you described. Just use lots of zip ties and welded some tabs on the axle for the lines. I run my Arb line there as well. Take a measurement and get some made at your local hydraulic shop.
post #3 of 3 Old 07-05-2018, 11:40 AM
NeverLift's Avatar
I will grab better pictures today for you. I ran a T at the center of the axles then 1 brake line up the upper arm.
Sent from my SM-G935V using Tapatalk
NeverLift is offline
