Tire Clearance/Rubbing - JKowners.com : Jeep Wrangler JK Forum
 6Likes
  • 1 Post By Uncle Sams Misguided Child
  • 1 Post By thedirtman
  • 1 Post By j3ff3ry_j33p
  • 1 Post By ALASHA
post #1 of 19 Old 06-20-2018, 10:35 AM Thread Starter
MAG00's Avatar
My rig is a '13 JKU (4dr) with a RK 3.5 lift, 3" bump stops, Nitto TG 37's, Currie VXR60s, with Spyderlock 3.5" BS wheels. Rig is on the heavy side with front and rear bumpers, winch, rock sliders.
I am getting a little tire rub. It seems as though I am fine at the rear, but I am getting a slight rub at the front. Happens at hard turns in parking lots ( if not taken slowly) and driving turns that have rough roads.
I've attached some pics of the tires when wheel is turned. I know that the Rubi rails extend just a hair past the sheet metal but just barely. Hard to tell much from the pics I know. It doesn't seem that the fenders are actually making contact. It seems that it is just inside at the fender liner near the bottom and body sheet metal which is covered by the liner. Hopefully that explanation makes sense. I'm not sure that going with flat fenders will clear it either. Just hard to tell.
What do you think is best option? Install 4.5" springs, 1" body lift, other? Do you think flat fenders will do it. 1" body lift would probably be the cheapest option, but would it look okay or be very noticeable? Thoughts?
'13 JKU Billet Silver, RockKrawler 3.5 lift, JRi Shocks, Currie VXR60s, Spyderlock Wheels, Nitto Trail Grapplers 37x12.50, ARB Twin with Lockers, PSC Hydro Assist, Superchips Flashpaq, Rubi Rails, Ace Rock Sliders, sPod, JCR Front & Rear bumpers, Engo 10KS Winch, KrawlOff-Road LEDs
MAG00 is offline
post #2 of 19 Old 06-20-2018, 12:14 PM
If it is hitting the sheet metal under the fender line then flat fenders isn't going to help with that. So you have the 2 choices 4.5 springs or the BL.
Or take a BFH to it.
post #3 of 19 Old 06-20-2018, 01:10 PM Thread Starter
MAG00's Avatar
Kind of what I was thinking. BL would be the cheapest I think, but I'm not sure how it would look.
MAG00 is offline
post #4 of 19 Old 06-20-2018, 02:10 PM
It would look like this. I have been running a 1" for 9 years now. I got mine from https://www.mountainoffroad.com/jeep...body-kits.html
post #5 of 19 Old 06-20-2018, 02:12 PM
or this
j3ff3ry_j33p likes this.
post #6 of 19 Old 06-20-2018, 03:31 PM Thread Starter
MAG00's Avatar
Thanks for the pics and link. Doesn't look like you can really tell that much. I don't guess it would effect the install of rock rails would it? I currently have rubi rails with Ace sliders.
I guess most difference would be seen at the front and rear bumpers.
MAG00 is offline
post #7 of 19 Old 06-20-2018, 04:19 PM
Push the front axle forward .25-.5"
Texas_Jester likes this.
post #8 of 19 Old 06-20-2018, 06:22 PM Thread Starter
MAG00's Avatar
Yea, that was the other option I was looking into. I have both upper and lower adjustable arms so I could adjust them equally to retain proper caster/pinion and push the axles out just a bit. Correct?
MAG00 is offline
post #9 of 19 Old 06-20-2018, 08:10 PM
You would be correct
post #10 of 19 Old 06-21-2018, 06:38 AM
The rubi rails mount to the body so they would go up as well. The ACE sliders though there would be a difference since they mount under the body mounts.
Dirtmans suggestion is probably the best and obviously costs nothing to do.
post #11 of 19 Old 06-21-2018, 08:32 AM
or this
all this time & ya know, I'd never seen your rig.
It's cool & looks setup well, ya old leatherneck...
post #12 of 19 Old 06-21-2018, 12:29 PM
I will have to get you a new pic then. back seat is gone, yellow and gold decals are gone.
post #13 of 19 Old 06-21-2018, 06:53 PM
ALASHA's Avatar
sawzall?
GobiRecon likes this.
ALASHA is offline
post #14 of 19 Old 06-22-2018, 06:26 AM
sawzall?
c’mon...this is a Marine !
= hand grenade or his teeth, pro’bly.
ndtguy likes this.
post #15 of 19 Old 06-22-2018, 08:36 AM
Az Scooter's Avatar
I have close to the same setup, except MetalCloak instead of RK. My 37’s rubbed on the sway bar. I ended up with spacers to prevent the rub.
Az Scooter is offline
post #16 of 19 Old 06-25-2018, 06:58 AM
I think he was referring to the OP.
post #17 of 19 Old 06-26-2018, 07:00 AM
well, that is awkward, innit-it?
I've failed (hard to imagine me doin' that, huh?)
post #18 of 19 Old 06-26-2018, 07:57 AM
We all have our bad days.
post #19 of 19 Old 06-27-2018, 07:51 AM
JeepGirl83's Avatar
<a href="https://www.jkowners.com/forum/images/smilies/jeep2.gif" border="0" alt="" title="Jeep2" >:-)</a>
Bad day? I’ve had a bad year!
2016 JKU Sport S Granite Crystal Metallic
Mods: 2.5" Teraflex lift kit w/ 9550 shocks, 1/2" front spring spacers, Teraflex JK 9550 steering stabilizer, Teraflex JK Front explorer bumper w/ hoop, Magnaflow axle back exhaust, Teraflex HD hinged carrier & adjustable spare tire, 17" Pro Comp Helldorado wheels, 35" MTZ P3s, Superchips Flashcal programmer, Freedom hardtop & Trektop NX, Brandmotion rear vision camera, remote start, Mopar slush and cargo mats, Wild Boar grab bars/handles.
JeepGirl83 is offline
