Simplify JK wiring to bare minimum - JKowners.com : Jeep Wrangler JK Forum
 3Likes
  • 3 Post By 0lllllll0 RPMEXTREME
post #1 of 7 Old 06-14-2018, 08:11 PM Thread Starter
so id like to start the process of turning my JK into a buggy-ish trail rig since its no longer on the road.
aside from hard parts like the drive train, id like to figure out how to simplify the wiring so it has the bare minimum to make the engine run.
i dont plan on doing a V8 anytime soon so the 3.8 will be sticking around so this will be what i have to work with. is there any sort of stand alone market for these engines? if not, what would be the best way to go about it?
Sent from my SM-G930V using Tapatalk
MISHIMOTO IS JUNK
chknkatsu is offline
post #2 of 7 Old 06-15-2018, 07:48 AM
ALASHA's Avatar
There is no stand alone that has a pre-made harness for the 3.8. You would have to build one yourself which I am guessing would be a somewhat challenging task since no one has done it before.
ALASHA is offline
post #3 of 7 Old 06-15-2018, 07:55 AM
ALASHA's Avatar
You could try to PM this guy and see if he ever came up with anything:
https://www.jkowners.com/forum/modifi...ne-wiring.html
ALASHA is offline
post #4 of 7 Old 06-15-2018, 08:23 AM
0lllllll0 RPMEXTREME's Avatar
You would need to keep the Jeep PCM, TIPM, Cluster, Ignition switch, WCM wireless control module to allow it to function without a ton of work.
I would just keep the stock harness intact and all components in place unless your ready to open a huge can of worms.
Just throwing this out there. We are working on a standalone harness that will allow you to drop in a complete 3.6 powertrain into a early JK or anything for that matter. This would be a better route than trying to make a 3.8 standalone. And the 3.6 pullout powertrains are really cheap right now and make way better power compared to a 3.8.
post #5 of 7 Old 06-15-2018, 08:31 AM
Treader's Avatar
RPM Extreme that sounds like a winner. Would this work with the updated 3.6 in the JL?
2010 2 door manual sport
Treader is offline
post #6 of 7 Old 06-15-2018, 04:37 PM
Im not sure about the JL 3.6 yet. Im not convinced its any better than the JK 3.6. They added a bunch of emissions stuff to the JL 3.6 and made it overly complicated IMO. I was told that this was to achieve the higher emission certification. LEV II+ I believe... don't quote me on this
Right now the JK 3.6 pullouts are stupid cheap and with proper tuning will make great power compared to the 3.8
post #7 of 7 Old 06-16-2018, 05:28 PM
NeverLift's Avatar
Start the jeep.
Cut one wire at a time till it shuts off.
Butt connect that wire back and keep going.
Really tho, there should be a pin out online somewhere and start there. I will be trimming wires shortly but it's pretty straight forward
Sent from my SM-G935V using Tapatalk
NeverLift is offline
