complete ABS removal - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By Rb6700
post #1 of 6 Old 06-13-2018, 07:52 PM Thread Starter
so i'd like to really start digging into my JK since it's been a dedicated trail rig for the past two years.
does anyone know how i can completely eliminate our ABS module?
MISHIMOTO IS JUNK
chknkatsu is offline
post #2 of 6 Old 06-13-2018, 08:15 PM
Rb6700's Avatar
You can just pull the fuses.
Rb6700 is offline
post #3 of 6 Old 06-13-2018, 08:42 PM Thread Starter
i want the module out of the engine bay so i have more room to work with. also to eliminate as much unneeded things as possible
Sent from my SM-G930V using Tapatalk
MISHIMOTO IS JUNK
post #4 of 6 Old 06-13-2018, 08:50 PM
Rb6700's Avatar
Your going to need a adjustable proportioning valve. Just pull the abs module out and lines run new lines to the new valve. This will be your starting point. You may need to replace the the master cylinder with one with a bigger bore. There is no kit to put put in, it's going to be trial and error.
chknkatsu likes this.
Rb6700 is offline
post #5 of 6 Old 06-15-2018, 04:43 PM
Hammered's Avatar
I pulled the abs module out and ran the lines straight to the master cylinder. Switched to 1 tons with chevy 1/2 ton brakes and it worked great.
Hammered is offline
post #6 of 6 Old 06-17-2018, 01:25 PM
NeverLift's Avatar
Pulled mine out and used a wilwood proportioning valve.
Besides the lights on the dash it works great.
Also the pedal is soft but they still work. I can stop fine.
Sent from my SM-G935V using Tapatalk
NeverLift is offline
post #7 of 6 Old 06-17-2018, 05:29 PM
0lllllll0 RPMEXTREME's Avatar
Do you still want your Speedo to work? If so you will need to leave the electrical portion of the ABS module in place as well as a wheel speed sensor.
