Weird steering issue - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 05-07-2018, 11:39 AM Thread Starter
Keith B.'s Avatar
Over the last month or so, I have had a weird steering issue come up. Randomly, a couple of times, I have had the steering lock up like the power steering was not working. It would occur for a few seconds. This weekend it happened for about 20 seconds and then went away. I have the stock pump and psc ram and box. Any thoughts?
07 JKU, 14 bolt rear/ Teraflex 60 front, Tera Long Arm, King Coilovers, 40" MT/R-Ks, Antirock etc. 430HP LS3 engine swap. Cage and 14 bolt swap thread-
Keith B. is offline
post #2 of 7 Old 05-07-2018, 01:22 PM
Check fluid level. It's likely just the stock pump going bad, it's an extra crappy pump worth upgrading.
christensent is offline
post #3 of 7 Old 05-07-2018, 01:40 PM
Rb6700's Avatar
Are you still using the factory high pressure hose? I'll bet the plastic inside the factory pressure hose is collapsing.
Rb6700 is offline
post #4 of 7 Old 05-07-2018, 02:05 PM Thread Starter
Keith B.'s Avatar
So my last one had a bearing go out and I just replaced it. I talked to Robbie at Motech and he said the factory ones actually were pretty decent but who knows. That was my first thought as well.
Keith B. is offline
post #5 of 7 Old 05-07-2018, 02:07 PM Thread Starter
Keith B.'s Avatar
Interesting thought. I will replace that as I have to take the front off anyway to fix my radiator. Thanks.
Keith B. is offline
post #6 of 7 Old 05-07-2018, 10:36 PM
Hmmm, that has not been my experience at all. My new one made bad sounds off the lot, then developed a fade above 2500RPM where it had no power steering above 3000RPM, then I replaced it with another OEM which immediately had poor behavior above 3000RPM and then through age lost almost all high RPM power steering.
Replaced it with a PSC pump and it works perfect now. Not to mention the amazingly improved steering speed with a higher flow pump running hydro.
post #7 of 7 Old 05-08-2018, 07:17 AM Thread Starter
Keith B.'s Avatar
I will probably do this upgrade. I have had a stock one for 4 years with no issues until now.
Keith B. is offline
