VKS V3 Stubby D Ring issue? - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By j3ff3ry_j33p
post #1 of 5 Old 05-06-2018, 08:58 PM Thread Starter
mastrcruse's Avatar
Just installed the VKS V3 Stubby bumper and love it. Wish I had a plasma cutter when removing the frame horns but got it done with what I had. I’ve looked at the pictures online and my supports stick out as much as others in pictures.
One issue I have, is that my d rings don’t fit. The vehicle end of the particular d ring I have (poison spider d rings) seem to be too thick. I’m probably a 1/4” off of being able to slide em’ in. Anyone else have this issue? Anyone running the V3 and which D rings are you using? Any other options?
mastrcruse is offline
post #2 of 5 Old 05-07-2018, 05:12 AM
maybe you’ve got 7/8” ,6.5 ton capacity d-rings & the VKS will only accept 3/4” 4.75 ton capacity shackles?
The website doesn’t really say, does it.
Ask Vick on here - @VKSFab I think it is - or call em.
tapcola likes this.
post #3 of 5 Old 05-10-2018, 12:48 PM
MeanGreenJKU's Avatar
I had the same problem and had to grind about 1/16” off of my warn d rings
MeanGreenJKU is offline
post #4 of 5 Old 05-10-2018, 01:30 PM Thread Starter
mastrcruse's Avatar
Interesting! I'm looking at VKS pictures and they're d ring attach points are definitely out more than mine. I beat the hell out of the bumper shell to make sure it was all the way on. I also noticed that they don't put in their instructions that if you have a larger winch, like my zeon, to NOT take 3/4" off the frame horns. My zeon is pushing my grill in pretty significantly.
I ordered synthetic d rings and those work well. I'll grind my d rings down like you had to. Thanks!
'14 Anvil JKU Sportis all that's in my garage.
What would I know though...I'm just crawlin' at the mall.
#TheBlacksmithCrew
post #5 of 5 Old 05-10-2018, 02:04 PM
Shadow_Grey's Avatar
My D rings fit perfectly on the VKS stubby even after powdercoating the bumper and rings...I know it isn't a V3 but they use the same D ring pattern...
Name:  Rubi cropped front shot.jpg
Name:  Rubi topless 2  4-9-17.jpg
Just a Jeep!
2010 JKU Rubicon Deep Water Blue Pearl TF CT4 Long Arm kit, HD adj track bars, high steer/flip kit, knuckles & ball joints AntiRock sway bars front/rear 5.38 gears, EVO sleeve/gusset/custom trussed Ten Factory Chromo axle shafts RH HD crossmember SB oil pan/trans/T-case skidplates KMC 17 x 9 Machete XD229 beadlocks 37" Toyo RTs SuperChip FP B&M Trans cooler SB flat metal fenders N-Fab steps/bars Ace aluminum inner fender VKS front/rear bumpers 11.5K Superwinch
Shadow_Grey is offline
