Need a heavy duty front track bar bracket for UD60 - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By billyjk7
post #1 of 18 Old 04-07-2018, 01:56 PM Thread Starter
I recently broke my front track bar bracket clear off the axle coming out of Pritchett canyon. Engineered it with a clevis and 3 straps. Drove it all the way out. You may notice the bolt in the picture being a way out. Needed to do that to tuck the bar close to axle to secure it better. Who has the most stout weld on to fit my Ud60?
Rancho Suspension likes this.
billyjk7 is offline
post #2 of 18 Old 04-07-2018, 06:40 PM
Are you running hydraulic assist steering?
post #3 of 18 Old 04-07-2018, 07:18 PM
Artec? Call and see if they can confirm it works on the ud60.
http://www.artecindustries.com/Raise...xle_p_661.html
2012 JKUS - Ripp SC - 4" TeraFlex - 37x12.50r17 TR HD17s - UD60s w/ ARBs
AEV Bumper - RR Sliders - TF Hinge - RockHard Skids
bigjimbo is offline
post #4 of 18 Old 04-09-2018, 10:55 AM
AllJumpStyle's Avatar
https://www.synergymfg.com/Synergy-J...t-p-31122.html
Chris Steimle
Product Manager
AllJumpStyle is offline
post #5 of 18 Old 04-09-2018, 03:44 PM
im a fan of the poly performance weld-on bracket
MISHIMOTO IS JUNK
chknkatsu is offline
post #6 of 18 Old 04-09-2018, 04:03 PM
Thanks! Poly Performance sells it, but it is a Synergy bracket.
Chris Steimle
Product Manager
post #7 of 18 Old 04-09-2018, 07:38 PM Thread Starter
So this will definitely fit the ud60?
billyjk7 is offline
post #8 of 18 Old 04-10-2018, 09:34 AM
Yes. We have two versions. One will fit the stock 2.5" axle tubes and one will fit oversized 3" axle tubes. It is a weld-on bracket, so will fit anything somewhat close to a 3" axle tube.
Chris Steimle
Product Manager
post #9 of 18 Old 04-11-2018, 10:04 PM
I put the synergy one on mine. I have hydro assist.
longlegs is offline
post #10 of 18 Old 04-11-2018, 10:49 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
I will third the Synergy bracket for the application. It comes with tabs for the hydro ram as well.
RiverCityOffroad is offline
post #11 of 18 Old 04-12-2018, 07:06 AM Thread Starter
how bout this one
Im a fan of all things Currie. This one is specifically for the 3.5 diam tube........Thoughs about this as opposed to the synergy one?
https://www.currieenterprises.com/jk...ck-bar-bracket
billyjk7 is offline
post #12 of 18 Old 04-12-2018, 08:20 AM
ALASHA's Avatar
Not a fan of having the track bar and ram mount off the same bracket. Just un-needed compound strain in my opinion.
ALASHA is offline
post #13 of 18 Old 04-13-2018, 09:56 AM
As long as the bracket is designed to take the load from the ram, it is a non-issue.
Chris Steimle
Product Manager
post #14 of 18 Old 04-13-2018, 10:06 AM
I beefed up the factory UD60 bracket and have been running it with PSC Hydro and 40s for three years without failure. As AllJump said there is nothing wrong with doing it this way if the bracket is done correctly.
post #15 of 18 Old 04-13-2018, 03:34 PM Thread Starter
I'm a fan of the currie do far....shoukd be able to mount right on the 3 5 tube without too much grinding it out. After talking to the guys there, I'm probably sold on it. Marcus......do you see any issues with it?
billyjk7 is offline
post #16 of 18 Old 04-17-2018, 08:58 AM
I am very close to buying a set of UD60s..can you elaborate on what you did to the bracket? BTW, I am likely going to buy the axles and PSC ram from you ;-)
For that matter can I pay you to brace it before shipment for a small fee?
1997 TJ --SOLD
1999 TJ --SOLD
2001 TJ --SOLD
2007 JK Unlmited Rubicon --SOLD
2013 JKUR Billet Silver-- SOLD
2016 JKUR White --
Marine01 is offline
post #17 of 18 Old 04-17-2018, 10:03 AM
Here you go brother! Let me know if you have any questions. I meant to come back here and post pictures but I got distracted the other day.
Here's how I reinforced my TB bracket. I also welded up the insides of the shock brackets because I used them for the coil overs.
post #18 of 18 Old 04-17-2018, 10:28 AM
Awesome, thanks!!
1997 TJ --SOLD
1999 TJ --SOLD
2001 TJ --SOLD
2016 JKUR White --
Marine01 is offline
