Pinion bearing help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 03-20-2018, 09:45 PM Thread Starter
Pinion bearing help
13 jk danna 30
need help anyone know part numbers for both the pinion bearings the inner and outer bearing thanks Iím running a arb locker so donít wanna buy a full rebuild kit
jkdune13 is offline
post #2 of 9 Old 03-20-2018, 10:19 PM
Originally Posted by jkdune13 View Post
13 jk danna 30
Depends what axle, check rock auto? Id buy a whole pinion kit if disturbing it
Sent from my SM-A520W using Tapatalk
libordemise is offline
post #3 of 9 Old 03-21-2018, 06:44 AM
Here you go, you gonna have to decipher all the numbers yourself.
https://www.morris4x4center.com/dana...angler-jk.html
post #4 of 9 Old 03-21-2018, 11:03 AM
Rb6700's Avatar
Dana 44 and 30 are the same bearings. It's almost cheaper to buy a rebuild kit after 2 bearings and a seal.
Rb6700 is offline
post #5 of 9 Old 03-21-2018, 11:13 AM
But a 60s not
post #6 of 9 Old 03-21-2018, 11:15 AM
Rb6700's Avatar
Originally Posted by libordemise View Post
But a 60s not
Poster ask about a Dana 30
Rb6700 is offline
post #7 of 9 Old 03-21-2018, 11:21 AM
So he did.
post #8 of 9 Old 03-27-2018, 06:10 AM Thread Starter
Pinion bearing help
Found g2 sells a d30 arb install kit with both bearing and shims and seal ordered the other seals as well and carrier bearing also
jkdune13 is offline
post #9 of 9 Old 03-27-2018, 08:15 AM
Crush sleeve?
