Overdrive - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By christensent
post #1 of 3 Old 03-11-2018, 09:44 PM Thread Starter
tapcola's Avatar
Overdrive
So I have 13 that I just regeard 513s on 37s and all in all I love it . But I think it No longer gose into OD.
I can get the Eco light to come on but I'm not sure it going into OD . If I hit the tapshift it says it's in 5th . Would it say something else?
SYNERGY, FOX,VKS,HUTCHINSON,
tapcola is offline
post #2 of 3 Old 03-11-2018, 09:48 PM
5th is OD on a 3.6L JK. It never says OD, just 1-5.
Unless something is broken, if it says 5 it's in 5th gear unless you gas it really hard to get it down-shift in manual mode (manual mode is will never up-shifts, and hesitates much more to down-shift).
5.13 gears on 37's and the 3.6L auto transmission should be doing 2700RPM at 70MPH. If OD is failing to work and you're in 1:1 4th gear, it'd be 3250RPM at 70MPH, so you should be able to determine what gear it's truly in by looking at the tach on the highway.
tapcola likes this.
christensent is offline
post #3 of 3 Old 03-11-2018, 09:54 PM Thread Starter
tapcola's Avatar
No that's about right thanks for the info !
tapcola is offline
