JK s Pulling Right? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 09-23-2010, 08:33 PM Thread Starter
SoK66's Avatar
JK s Pulling Right?
JKs are notorious for pulling to the right, right? The fix has been to stagger the right caster a bit more than the left to compensate. TF suggests having the right front lower control arm 1/8" further forward than the left. Works like a charm. After installing manual (Spyntec) hubs and not having everything up front spinning all the time guess what? It pulls to the left. Set the arms same-same on both sides, no more pull. The rightward pull must have something to do with the unequal length but same strength front axle shafts spinning all the time. VW cured this on their FWD cars by using unequal strength axle shafts...in 1974. Just thought I'd mention it....
SoK66 is offline
post #2 of 7 Old 09-23-2010, 08:42 PM
slacktide's Avatar
Um im thinking its because the road slops to the right. Try riding on the left side of the road and it just might pull to the left???
37s on Raceline Beadlocks 5.38 Yukon Gears
slacktide is offline
post #3 of 7 Old 09-24-2010, 04:56 PM
dougnpj's Avatar
put air in your right front tire???
dougnpj is offline
post #4 of 7 Old 09-24-2010, 05:17 PM
desert dog's Avatar
Yep, it is a known problem. And yes TFs solution worked great for me too.
desert dog is offline
post #5 of 7 Old 09-24-2010, 07:01 PM Thread Starter
SoK66's Avatar
Factory also has the RF caster greater than the LF.
SoK66 is offline
post #6 of 7 Old 09-24-2010, 07:05 PM
slacktide's Avatar
Not really sure, i never had the problem even running 37s
post #7 of 7 Old 09-24-2010, 10:53 PM
desert dog's Avatar
Uh Ohh. Be careful there. I got flamed pretty hard several months ago for mentioning that
