Tire width and backspace? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 09-23-2010, 01:52 PM Thread Starter
Being new to JK's I'm still unclear as the max backspacing that can be used with a 12.5" wide tire?
Thanks, Linda
Dirty Mudder on FB
'01 Wrangler Sport, Sienna Pearl Mine
'07 Rubicon 2D, Flame Red His
DirtyMudder is offline
post #2 of 5 Old 09-24-2010, 01:04 AM
rim bs
hey there thought id chime in after i just went throught 3 sets of rims to get it perfect, i highly recommend a back space of 4.5 inches the offset should be slightly negative from 0mm to -25mm for example this works great for 17 inch rims if you do use a 15 inch which did u MUST use a backspace of 3.6 and a huge negative offset of -46mm example pro comp 8179s, only this much backspace allows you to clear brakes but puts much more stress on you wheel bearing tie rod ends and ball joints from my experience. get some 17x9, rims perfect with 4.5 backspace. remember the smaller the backspace number the wider it sticks out factory is 6.5 i think. more than 5 is too far under jeep less than 4 is too far out...goodluck i feel that most jk owners would agree
DBrosJeep is offline
post #3 of 5 Old 09-24-2010, 12:10 PM
crazychaser's Avatar
Max BS for an 8" wheel is probably 3.75". Anything less than 3.75 is going to stick out of the fender way too far IMHO.
I'm running a 16x8 wheel with 4.5 backspace with 35/12.50 tires and I couldn't be happier.
[Don't pretend you care what I've done to my rig]
crazychaser is offline
post #4 of 5 Old 09-24-2010, 12:15 PM
I Wish my wheels were 4.5 - 4.7" BS.. I Like how AEV's wheels pretty much stay underneath the factory flares.
I have 4" BS now on 15x8" wheels.. they stick out about an inch...
no jeep here...
Racer83l is offline
post #5 of 5 Old 09-24-2010, 02:46 PM Thread Starter
Thanks guys! Sounds like 4.5" or less would be best...
Dirty Mudder on FB
