Programmer for 3.5" Lift and 35's? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 09-23-2010, 01:39 AM Thread Starter
bluerubicon08's Avatar
So I am getting ready to pull the trigger on a RK 3.5" lift and some 35x 12.50 Mud Grapplers. Do I need a programmer? If so, which one?
If you're gonna be fucking weird, own it.
~SoCo
______
bluerubicon08 is offline
post #2 of 13 Old 09-23-2010, 05:57 AM
taxman's Avatar
No. You don't NEED a programmer. You may WANT one, but you don't NEED one. I've been running 35s for a few thousand miles and although the speedometer is off a little, it doesn't bother me. Plenty of power and I shift when I want to. I have a 6-speed Rubicon though.
If you have an unlimited with automatic transmission with anything less than 4.88 gears, you'll want a programmer like the Superchips Flashpaq to give you some more perceived power by changing the timing of the shifting points and a few other cool features.
2018 JL Rubicon Unlimited, 6-speed, White
1985 CJ-7, 4-speed, 258 I-6, 3" Springs, 33" BFG AT, Gunmental Gray
taxman is offline
post #3 of 13 Old 09-23-2010, 06:31 AM
Cod
Cod's Avatar
Send a message via MSN to Cod
Originally Posted by taxman View Post
Superchips Flashpaq .
2'nd That!
Cod is offline
post #4 of 13 Old 09-23-2010, 06:46 AM
StepsRide's Avatar
which RK kit are you going for?
StepsRide is offline
post #5 of 13 Old 09-23-2010, 08:29 AM
XJK07's Avatar
I used the Superchips to recalibrate the speedo with tire size. I have about the same amount of lift, and 35" tires. Its useful because you can check engine codes with it as well.
XJK07 is offline
post #6 of 13 Old 09-23-2010, 09:30 AM
ALASHA's Avatar
Diablo Predator
You can adjust for tire size, load the performance tune and a hole bunch of other stuff.
ALASHA is offline
post #7 of 13 Old 09-23-2010, 10:35 AM
Taxman....What about your ABS? Isn't that impacted?.....I'm thinking of doing the same and I don't care about the speedo difference since I have a 6 spd also but the ABS is my concern.
blackjk2010 is offline
post #8 of 13 Old 09-23-2010, 11:06 AM
taxman's Avatar
Why and how would ABS be affected? I haven't read of any problems with ABS due to larger tires or lifts. I've read about ESP issues when your axles aren't aligned/centered properly due to using the stock track bars with no relocation brackets, but never heard of ABS issues.
ESP uses ABS to control traction. Maybe that's what you're referring to?
taxman is offline
post #9 of 13 Old 09-23-2010, 11:13 AM
when i went to 33's from the stock 32" (waste of time and money) My JK had an active code when scanned with the starscan about the ABS, no light and it worked fine... so somehow someway it does make a difference....
If you have an Auto, get a programmer. AEV's Pro-cal is a good unit for the price, if you want to spend some extra coin go with the superchips, it does add a few HP. In NY I believe it is illegal to have an incorrect speedo, so here anyways you would technically NEED one to be legal.
no jeep here...
Racer83l is offline
post #10 of 13 Old 09-23-2010, 11:29 AM
taxman's Avatar
If all 4 tires are the same size, there should be no way that the ABS would trigger an error. The only thing I can think of is that if the ABS system monitors the speed of each wheel independent of the others, the ABS system may react differently to a wheel that is travelling at 60mph vs one travelling at 65mph - different pulse rates, pressure, etc. If the speedometer is not properly calibrated, the ABS sensor may think you're going 60mph when you are actually going 65mph. The incorrect adjustments may be applied and the wheel may not respond as it's supposed to and then an error is generated.
I've never received an error and my lights have never turned on. I would move on. The NY illegal thing has merit though, especially if they test speedometer accuracy as part of routine annual inspections. They don't in NC.
taxman is offline
post #11 of 13 Old 09-23-2010, 12:05 PM
What I'm refering to regarding ABS impact is that (with cars anyway) there usually is a tolerance set around 3 to 4% change in overall tire size before the ABS monitoring is impacted. The actual tolerance varies by manufacturer. If you check out some tire retailers, they will specify this as being a restriction as to what wheels/tires combo you can use.
With cars when you go to larger wheels but with lower profile tires, you need to keep the overall size the same to not impact the ABS, but with Jeeps since the object is to get a bigger overall size, I'm not sure what happens then. When I put larger tires on my last Jeep TJ, I didn't have ABS so it wasn't a concern to me. Now with my JK, I have ABS.
post #12 of 13 Old 09-23-2010, 12:11 PM
taxman's Avatar
I understand what you are referring to. But how does your Jeep know what size tire (overall diameter) you are running? It only knows to calculate speed and adjust accordingly. ABS knows that a specific speed is equal to a set number of revolutions per second. It doesn't see or feel the difference in overall size.
taxman is offline
post #13 of 13 Old 09-24-2010, 02:23 AM Thread Starter
Thanks for the input guys............I was under the impression from some other posts on the forum that a programmer was a "must" with the lift and tire change. I can see some advantages with some of the features, but since I also have a 6-speed Rubi, I can feel when to shift my vehicle, I've only been driving a stick for 35 years.
Steps, I am torn between the 3.5 entry level, and the 3.5 Mid Arm Flex.
~SoCo
______
