New Shocks or whole new lift system? - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By SilverBulletJKU
post #1 of 4 Old 02-25-2018, 03:53 PM Thread Starter
SeptemberC's Avatar
So the lift kit that is on the Jeep right now is a 2.5” Pro Comp. & from the 2013 time frame.
Some guy in Lowe’s parking lot stopped me to comment on the Jeep and said "You need to get (marble mouthed blah blah & I couldn't understand) shocks. You could drive right over that curb and it wouldn't jar you outta your seat." I thanked him for complementing my Jeep and drove home.
Not that I think he was ANY kind of expert but I did find myself thinking about how rough I've noticed the ride has been with the falling apart pot hole roads here in WV.
My question is there just a set of shocks I could get or would it be a whole new lift kit system? If just shocks... what would be recommended for a daily driver that I take to the hills over the weekend? I do tow jet skis too if that matters any at all.
2013 Jeep Wrangler MOAB JKU Bright White
Sent using Tapatalk
SeptemberC is offline
post #2 of 4 Old 02-25-2018, 10:07 PM
Definitely some triple bypass, coil over, remote reservoir shocks
Or use rancho 9000, fox, or bilstein shocks in the appropriate length. All shocks wear out over time and either need to be replaced or serviced periodically.
UFDUB is offline
post #3 of 4 Old 02-26-2018, 04:11 PM
SilverBulletJKU's Avatar
Like UFDUB said, shocks wear out over time and need to be replaced. I would look into either some Fox 2.0 Series shocks or some Bilstein 5100s, they are highly rated and not too expensive.
SeptemberC likes this.
SilverBulletJKU is offline
post #4 of 4 Old 02-26-2018, 10:15 PM
I have been happy really with the fox 2.0 w/ reservoir that came with my synergy stuff. I am coming from 3.5 inch kings with bypasses on a desert bound dodge ram so I am not easily impressed by shocks. I think fox did a really good job with what is considered off the shelf valving. I will go to a bigger shock once my end setup is kind of dialed in for all around speed and flex.
OR2BAJA is offline
