Track bar lower mount holes too big - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 02-23-2018, 10:56 AM Thread Starter
Well.... for the past month or so, i have been having an intermitent and slight wooble on the steering wheel... once when i hit a bump at speed, it increased, but usually its not very noticeable.... so today i removed my track bar (i have a 2.5" Rock Krawler stock mod suspension), and I noticed the PO had already replaced the lower bolt with a 9/16" bolt.
now, the holes in the mount look as if they are too big, they dont look too oval, but the bolt definitely has a lot of play in there. Is there a way of fixing this issue?
2007 JKU, 2.5" Rock Krawler lift, 285/70 17 mud terrains....
shu2kill is offline
post #2 of 5 Old 02-23-2018, 11:11 AM
gt1guy's Avatar
Sounds like some weld washers would fix you right up.
Fix it Weld Washers, Set of 6 - RuffStuff Specialties
Kevin
gt1guy is offline
post #3 of 5 Old 02-23-2018, 11:13 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Are you sure thats a 9/16 bolt? Go grab a grade 8 from the hardware store and compare just to be sure. You want a 9/16-18 shouldered bolt.
If that doesn't do the trick you can replace the bracket with a weld on Artec unit or put a raised track bar bracket on it. Or weld some washers on the hole.
RiverCityOffroad is offline
post #4 of 5 Old 02-23-2018, 02:09 PM Thread Starter
Yes I am sure thats 9/16, I measured with a vernier. Besides, the bolt fits tight on the trackbar. Any bigger bolt wouldnt fit.
Thank you GT1guy for the link. I didnt know those existed. But I am in Mexico, and I couldnt find them locally.
So, we made these out of some scrap material we had in the shop. We now will TIG weld them in place. I think that should be enough, they are thicker than the original plate.
shu2kill is offline
post #5 of 5 Old 02-24-2018, 08:52 AM
gt1guy's Avatar
That will work too. And they were cheaper!
Kevin
gt1guy is offline
