PSC Pump Advantage ?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 09-22-2010, 06:53 PM Thread Starter
I'm running the stock pump with a new PSC Steering Assist kit. It works fine although in fast turns, it feels like the pump falls behind on volume and pressure. It's ok for now and has considerably more power in the rocks. Two questions. Are there any warning signs of impending stock pump failure? And , how does the PSC pump affect the performance compared to stock?
97 ZJ 5.2, Atlas, hp30, 8.8, alloys, locked F&R, Clayton LA lift, 35" KM2's
97 TJ 110" WB, Atlas, 350 chevy, D60, 14B, 42" Pit Bulls.
Venturer is offline
post #2 of 11 Old 09-23-2010, 05:41 AM
If you have 6 speed manual stick with your stock pump and get it ported they work much better than psc pump if yoh have an auto psc pump is good more high flow but you need to run the their bigger reservoir with filter and a ps cooler
JK07 is offline
post #3 of 11 Old 09-23-2010, 05:57 AM Thread Starter
Are there any warning signs of impending pump failure or does it just lockup?
Venturer is offline
post #4 of 11 Old 09-23-2010, 09:41 AM
RIP Brad
abendx's Avatar
I'd guess it will get really noisy before it goes.
abendx is offline
post #5 of 11 Old 09-23-2010, 10:59 AM
Impulse Off Road's Avatar
I just installed the new PSC pump with the chevy internals and the no leak reservoir on my JK. The installation was very straight forward and simple. The new pump made the ease of turning the same at all rpms. There was no more lag in the steering at slow speed. The steering feel was greatly improved in every aspect. Worth every penny in my book.
Impulse Off Road is offline
post #6 of 11 Old 09-23-2010, 11:21 AM
km2jk's Avatar
Do you have a part number for that pump? Which transmission are you running?
TNT Customs
Genright
Poison Spyder
Or-Fab
River Raider
Mastercraft
Spod
M.O.R.E.
Goodyear
Diablosport
km2jk is offline
post #7 of 11 Old 09-23-2010, 07:05 PM
joeglock's Avatar
Send a message via Yahoo to joeglock
What does the transmission have to do with the PS pump? keep hearing people talk about the tranny and ram assist. maybe i am to dense but what does one have to do with the other?
joeglock is offline
post #8 of 11 Old 09-23-2010, 07:26 PM
km2jk's Avatar
I wish I knew the answer to that also. I've heard of some fairly major issues with the full PSC system and the 6-speed trans
TNT Customs
Genright
Poison Spyder
Or-Fab
River Raider
Mastercraft
Spod
M.O.R.E.
Goodyear
Diablosport
km2jk is offline
post #9 of 11 Old 09-23-2010, 08:05 PM
2k2wranglerx's Avatar
because rather than being at 800 rpm as you turn into a parking spot, generally you're at a higher RPM (since your foot is on the clutch and a quick rev is all you need) which turns the pump faster.
2k2wranglerx is offline
post #10 of 11 Old 09-23-2010, 08:08 PM
PSC setup does NOT work well with manual 6 speed transmisson that is bec of low engine idle speed.
With Auto transmission the engine idle speed is up all the time when in drive compared to manual so it works very well.
JK07 is offline
post #11 of 11 Old 09-23-2010, 08:09 PM
It would be really good if you post some pics and more details on this pump, part number, price , install etc etc
JK07 is offline
