My jk punisher build - JKowners.com : Jeep Wrangler JK Forum
 2Likes
post #1 of 34 Old 02-16-2018, 06:20 PM Thread Starter
Figured I would post my build here, long story short version. Had a shop install all the mods below, had huge issues and found a awesome shop. I found out that bolt on Coilovers I got just don't cut it so decided top 4 link the rear and run Coilovers thru tub. The 4 link works flawless so far, at full flex heim isn't even moving off center. Below is progress
Jeep mods:
JEEP MODS
Dana 60 Front 5.38
Dana 60 Rear 5.38 with custom gusset for 4link
Dodge 1 ton BBK master cylinder & booster
Dodge brake cable
Synergy HD rear track bar (not using)
Synergy HD front track-bar
Fusion 2.5 ton drag-link
Fusion 2.5 ton tie-rod
Long arm kit fabricated by shop, 4/4" heime 1.5" lower heim
Front Anti-rock swaybar kit
Rear Anti-rock swaybar kit (not using)
PSC power steering cooler
PSC hydro Steering Stage 5
PSC tie-rod clamp
Rebel off-road coilovers (14" travel W/king shocks)
Poision spyder rocker guards
JCR fender delete kit
JCR inner fenders
Ace bumper armor
JCR rocker armor
DV8 tire carrier
Pit bull Rocker 42" bias ply
B.A.D beadlocks
JWS evolution J headlights
Warn xeon 12,000lb winch W/sythetic rope
Rock hard 4X4 cage
Rigid industries 50" variance light bar
Rigid industries dual variance pod lights
Genesis off road dual battery kit
ARB air compressor kit
AFE high tuck exhaust
Top fire furry grill
Spod HD
All suspension powder coated red
moddedbmw is offline
post #2 of 34 Old 02-16-2018, 06:21 PM Thread Starter
More pics
UFDUB likes this.
post #3 of 34 Old 02-16-2018, 09:50 PM
terrahawk's Avatar
Weren't you trying to sell this?
terrahawk is offline
post #4 of 34 Old 02-16-2018, 10:11 PM Thread Starter
I actually was, then saw some of the horribly done mistakes on it and would not let anyone buy it like that, started fixing everything then decided to just go full blown with it. Other shop is currently being sued lol!
It was bad, real bad. All fixed now and love it.
post #5 of 34 Old 02-16-2018, 10:23 PM
Good call on ditching the bolt on coil overs.
Conventional coils and shocks on the rear?
I would have moved the lower rear arms up on both the axle and frame for better clearance.
post #6 of 34 Old 02-17-2018, 12:49 AM Thread Starter
I have a ton of clearance and the angles where just to perfect. I ditched the bolt on rebel kit in rear (puts Coilovers at 35 degrees and they hardly ever flex at full flex ) Coil overs will be mounted on axle via brackets (around 2" on bump pad) and they are going thru tub. Frame will be notched and of course be built back up and strengthed. Then brackets on cage will be used for top of coilovers. They will be between 5-6 degrees.
post #7 of 34 Old 02-17-2018, 12:53 AM Thread Starter
Those spring perches will be all cut off, using king Coilovers with 4" travel bump stops. Like this but my coils will be on out side of frame.
post #8 of 34 Old 02-17-2018, 12:54 AM Thread Starter
I will have more bracing/gussets than pic above
post #9 of 34 Old 02-17-2018, 08:25 AM
I was speaking of clearance to rocks and ledges hanging the lowers off the bottom of the frame. If you've the axle side up so the control arm bracket is not hanging below the axle and inside the frame the angle would be the same and you gain a lot of clearance mainly for everyday trail running.
post #10 of 34 Old 02-17-2018, 11:59 PM Thread Starter
Very good point, may run this ny my fabricator
post #11 of 34 Old 02-21-2018, 09:08 PM Thread Starter
More pics of 4link fabrication, arms will be red, truss black, differential cover red, all welds will be cleaned up ect
post #12 of 34 Old 02-22-2018, 04:28 AM
DJ1
DJ1's Avatar
If you haven't upgraded your crossmember/skid system yet, you can run something like the Clayton or Artec crossmember that allows the lowers to get tucked in/up more.
I'd recommend going with the CM whose skids you plan to use...
JK HD Crossmember with Link Mounts
https://www.claytonoffroad.com/jeep_...r_2012_2017_jk
https://genright.com/products/jeep-j...kid-plate.html
DJ1 is offline
post #13 of 34 Old 02-22-2018, 01:34 PM Thread Starter
My lowers are connected to inside of frame rail, my arns are a 70/30 instead of equal because my rig is a daily driver and crawler. That was the goal anyway lol!!
The skids I was leaning toward artec for sure but shop has plasma cutter ect so they are going to make the skids.
post #14 of 34 Old 02-26-2018, 12:35 AM Thread Starter
Cut the tub today to get Coilovers thru, of course this is raw not done lol
post #15 of 34 Old 02-26-2018, 12:35 AM Thread Starter
More pics
post #16 of 34 Old 03-11-2018, 12:40 AM Thread Starter
Got frame notched, got Genright girl cell, also integrated cage into frame.
Started to dial in flex, had much more than pic and joints are still centered.
Also got PSC bracket welded on.
post #17 of 34 Old 03-11-2018, 11:23 AM
I would not trust that PSC mount to that bracket. Lots of leverage there and will likely rip off when you are in a bad spot.
post #18 of 34 Old 03-11-2018, 02:13 PM Thread Starter
That's just raw it, still gets boxed in, and also gets a gusset. Shop has same bracket on there competion buggy and that thing takes some serious abuse.
The dana 60 spot for PSC that 90% of people use is a lot weaker, they weld the bracket only on one side and also have the PSC in wrong angle creating a lot of stress.
I honestly trust this shop 100% with this, I should have mentioned it being reinforced.
post #19 of 34 Old 03-13-2018, 07:38 AM Thread Starter
Better pic
post #20 of 34 Old 03-13-2018, 12:23 PM
tapcola's Avatar
Better pic
I would be more concerned with where it's mounted to the axel , the bracket itself isn't welded on that well .
You are using a stock TB bracket? Not a raised bracket of any kind ?
SYNERGY, FOX,VKS,HUTCHINSON,
tapcola is offline
post #21 of 34 Old 03-13-2018, 01:10 PM
From that shot it looks like your tie rod is going to hit the ram body.
post #22 of 34 Old 03-13-2018, 01:35 PM Thread Starter
Not going to hit anything, all tested on vehicle, as you will notice the boxed in piece is lowered . It is has 1/4" clearance at full lock To lock. Even tested it fully flexed add it clears perfectly.
Also this puts ir in better plain so much less stress on the ram bracket.
post #23 of 34 Old 03-13-2018, 01:40 PM Thread Starter
I agree the dana 60 bracket is actually not welded on great, they don't weweld the inside at all. Mine is welded from both sides. Then boxed in to the axle again. No way this will bend. I had it connected to the stock track bar for a year and nothing bent at all. Didn't like the plain it was in. This is thick 1/4" also.
Below is pic where it was with no reinforcement like now.
post #24 of 34 Old 03-16-2018, 07:03 PM Thread Starter
That pic was very deceptive lol
post #25 of 34 Old 03-16-2018, 07:07 PM Thread Starter
Got axles painted, diff covers will be taken off and powdercoated, we decided on paint for all arms as it makes touch up much easier since they are going to get mangled lol!
