Stability control light??? - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By Pmedic920
post #1 of 4 Old 02-16-2018, 12:16 PM Thread Starter
Pmedic920's Avatar
I just completed installing my suspension up grade.
Within 8-10 miles on test drive, my stability control light came on.
Iím assuming that itís because I didnít re-center my steering wheel.
I didnít do that because itís headed to the shop for complete alignment.
1)is my assumption safe/correct?
2) is there any real danger in driving a couple days with the light on, or should I crawl back under a center the wheel myself?
Thanks in advance.
Pmedic920 is offline
post #2 of 4 Old 02-16-2018, 12:53 PM
Rb6700's Avatar
Thanks in advance.
Get under there and re center it. The jeep will think your in a slide and keep applying the brakes.
Rb6700 is offline
post #3 of 4 Old 02-16-2018, 03:15 PM
Yup, this is the issue. Your Jeep will compare the angle of the steering wheel to the wheel speed sensors and think that you are out of control.
Adam C
post #4 of 4 Old 02-17-2018, 06:57 AM Thread Starter
Pmedic920's Avatar
Thatís what I thought.
Wheel centered.
Two engine restarts and 12 miles, light turned off.
Memo: center your steering wheel after any work that moves it off center.
Itís easy, so easy even I can do it.
Thanks guys.
