Another Hydro Assist question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 09-21-2010, 07:35 PM Thread Starter
Has anyone tried tapping the box or the tower on a JK steering box on their own? Trying to do hydro assist on the cheap...
I have the tools, just need to know where to drill and tap the holes.
Mark
mshogren is offline
post #2 of 7 Old 09-21-2010, 08:48 PM
Dont quote me on this but I think where you would add the ports either requires a thicker casting or welding fittings on. I believe that area is aluminum & im not sure what quality the material is & how it would turn out.
You can buy the kit for $420...
LINK
The ram alone is $115.00
Hoses $75.00 +/-
Figure your paying $220.00 for the new ported cap.
Plus if you screw something up & waste the pump or have a failure on the trail your out more coin & headache.
Is the juice worth the squeeze ?
Check out that pic of the new cap. It will give you an idea of where your trying to tap into for pressure lines.
Thean Bellocchi
Poly Performance Inc.
Sales & Tech Support
805-783-2060 Ext. 200
crusty1007 is offline
post #3 of 7 Old 09-21-2010, 09:15 PM
That is the kit that I just bought. See my post re: Power Assist Fluid. Their block will work if you have a pre 2010 JK. As I said in my post it works great. Eventually I will add the PSC pump, but it's not needed yet. At that price, I wasn't going to attempt to drill my own. The tower is $179. I built my own axle mount that reenforced the tracking bar mount too, and bought their tie rod clamp. Be sure and measure the stroke needed for the ram like they say on their tech site. I had to take the ram apart and build a longer block to shorten the stroke to match my needs.
That round silver thing in the picture is just a display stand.
97 ZJ 5.2, Atlas, hp30, 8.8, alloys, locked F&R, Clayton LA lift, 35" KM2's
97 TJ 110" WB, Atlas, 350 chevy, D60, 14B, 42" Pit Bulls.
Venturer is offline
post #4 of 7 Old 09-21-2010, 09:45 PM
BenFoo's Avatar
Ill be installing one of those later this week.... Just waitin on those PSC parts. I have the rest of the bracketery from Poly sitting around..
As I said in another post, ill let you know how it works out.
BenFoo is offline
post #5 of 7 Old 09-22-2010, 02:23 PM
TrailDuty.com
PhilD's Avatar
No reason why you can't. If you need some pics of where WTO drill and tap just LMK.
PhilD is offline
post #6 of 7 Old 09-22-2010, 02:39 PM
BenFoo's Avatar
UPS man just arrived with this.
That picture does not due the new ported cap justice.
Ill see if i can get some pics up soon.
BenFoo is offline
post #7 of 7 Old 09-22-2010, 06:27 PM Thread Starter
Decided to just bite the bullet and get the PSC economy kit, would not save enough money to justify the risk of my daily driver being down due to a screw up...Thanks Thean!
Mark
mshogren is offline
