lift kit - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 02-09-2018, 12:53 PM Thread Starter
lift kit
I wanted to ask. A guy i work witk has a jku and he is wanting to put a .75 leveling spacer on it with 33's. He was told they would rub. I told him that I did't think they wouldn't rub but whats everyone's thought on it. Thanks Ben
Bigben42 is offline
post #2 of 4 Old 02-09-2018, 04:21 PM
Rb6700's Avatar
The tires will rub at full turn unless if he's buying new wheels also. Then he will need to go with a 4 inch back spacing. There are hundreds of threads on this.
Rb6700 is offline
post #3 of 4 Old 02-09-2018, 06:09 PM
Depends more on the width of the tire. If doing a10.5" wide tire he should be good. If doing a 12.5" wide tire on the factory wheels then it may rub a bit at full lock. He may also need a little bump stop added to the set up as well if he disconneects off road.
post #4 of 4 Old 02-11-2018, 02:39 PM Thread Starter
thanks guys for the info.
Bigben42 is offline
