15" Wheels on a Rubicon? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 09-21-2010, 01:02 AM Thread Starter
bluerubicon08's Avatar
Does anyone know if there is a defined list of 15" rims that will work on the Rubicon?
If you're gonna be fucking weird, own it.
~SoCo
______
bluerubicon08 is offline
post #2 of 14 Old 09-21-2010, 04:12 AM
casaintsfan's Avatar
Send a message via AIM to casaintsfan
We can start one, my pro comps fit my rubicon.
But I'm sure there are many threads already started.
casaintsfan is offline
post #3 of 14 Old 09-21-2010, 04:41 AM
slacktide's Avatar
I have these and there for sale
37s on Raceline Beadlocks 5.38 Yukon Gears
slacktide is offline
post #4 of 14 Old 09-24-2010, 03:43 AM Thread Starter
Bump?
~SoCo
______
post #5 of 14 Old 09-24-2010, 06:50 AM
BigMike's Avatar
See My Build thread in my signature.
You need a 15" wheel that has 3.75" backspacing. I have Pro Comp Rock Crawler steelies on my Rubi.
, Granite,
BigMike is offline
post #6 of 14 Old 09-24-2010, 06:54 AM
planman's Avatar
Do you want steel or aluminum?
Here is one list of mostly steel wheels:
https://jkowners.com/forum/showthread.php?t=31104
planman is offline
post #7 of 14 Old 09-25-2010, 01:13 AM
vwang's Avatar
x2 on the pro comp with 3.75 bs
Teraflex - Poly Performance - Poison Spyder - Off Road Hero's - Rugged Ridge - Superchips - Goodyear - aFe
vwang is offline
post #8 of 14 Old 09-25-2010, 01:21 AM Thread Starter
I was leaning towards aluminum. I'll be honest, I love the Walker Evans, but I'm a havin' a hard time coming up with the scratch for them! I'm thinking if I can switch to a 15" rim, then the rims will pay for themselves with the money I'll save in rubber over the years.
How's that for justification?
~SoCo
______
post #9 of 14 Old 10-04-2010, 06:52 PM
I know a guy that runs Mickey Thompson classics, 15x8 but not sure on the back spacing.
post #10 of 14 Old 10-05-2010, 12:30 AM
I have 4" bs soft 8s on my rubi ul. I just barely had to grind the caliper to make them fit. The backspacing has zero bearing on whether or not you will have to grind. The center of the rim is where it is no matter the bs. The part you may have to grind is completely insignificant. FYI if you do not have to grind upon initial install of soft8s you probably will after doing new brake pads. I also had 15" black rock 909s on my sahara and they were also 4" bs and they cleared by a mile. I also have a solid black one for my spare on my rubi to save weight on the stock tailgate.
Hardcoreheath is offline
post #11 of 14 Old 10-05-2010, 12:37 AM
paramaniac's Avatar
I've got 15" Cragar Soft 8's and haven't had to grid my calipers, I even just replaced my brake pads and still no rub
paramaniac is offline
post #12 of 14 Old 10-05-2010, 12:41 AM
It's really hit or miss. Between how well the wheels were punched and welded and how well the calipers were smoothed out after casting. All I had to do was smooth out the casting flash on the caliper strap, and I was fine. Have you rotated the tires yet?
post #13 of 14 Old 10-05-2010, 12:44 AM
paramaniac's Avatar
Just did my first rotation and continue to be rub free
post #14 of 14 Old 10-05-2010, 07:40 AM
Can you get some more info on this???
gcally is offline
