Snatch Blocks ???? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 02-07-2018, 08:24 PM Thread Starter
Pmedic920's Avatar
Snatch Blocks ????
Do I need anything special to work with a synthetic line?
Has anybody ever had a snatch block damage a synthetic line?
Im seeing a wide range in prices on them, anybody care to share what they use, or recommend a good bang for the buck option?
Thanks in advance for your input.
Pmedic920 is offline
post #2 of 17 Old 02-08-2018, 03:46 PM Thread Starter
Pmedic920's Avatar
Snatch Blocks ????
Seriously?
Almost 100 views and not 1 opinion?
Could a guy get a little help up in here.
I get it, Im the new guy but yall might as well get used to me, I aint goin nowhere soon.
post #3 of 17 Old 02-08-2018, 03:46 PM
gt1guy's Avatar
I'd also like to know about use with synthetic line.
I have a few of the ARB snatch blocks. I can say I've treated them roughly and they're still holding up fine.
Can't go wrong with anything from Crosby, but you'll pay.
Kevin
gt1guy is offline
post #4 of 17 Old 02-08-2018, 09:11 PM
I believe this Billet4X4 - 4x4 Recovery Gear - Winches is where I got mine from. Look for something that's spec'd for your size line and rated at twice your winch rating. Have used mine a couple times with the expected results. I also grabbed one of their tree savers.
I bought Crosby shackles, because that's what the internet says you have to use, and have had zero issues.
Spend the money up front for decent recovery gear. Not much worse than broken gear/tools when you need them.
2014 JKUR, manual, Metalcloak 3.5" lift, 35" MTR's on stock wheels, SPod, Baja Designs, VKS Pre-Runner rock sliders
rebltrubi is offline
post #5 of 17 Old 02-09-2018, 04:03 AM
make sure the pulley is smooth and has not been used with a steel line. I have used a cheap HF snatch block many times with my synthetic Warn line and never an issue but I check it each time to make sure the pulley is smooth.
Jadmt is offline
post #6 of 17 Old 02-09-2018, 04:59 AM
Eburgpirate's Avatar
This ^^^^^^^ I run a 235' fishing vessel, We use up to 1-1/2" spectra or an equivalent, All the sheaves in our blocks are SS, I don't believe that is necessary in this case, but a burr free sheave is, and as stated above, not a block that has used wire.
08'Rubicon, 37" Radial Trepadors, DIY beadlocks,10 Factory rear axles,RCV front shafts,Sleeved front,C-gussets,5.38's,OBA,highlift,Warn,
PSC fenders,corners,rocker knocker, BFH rear, Warn front, Classic Cobra 29,Carpet delete, hurculinered tub.
Eburgpirate is offline
post #7 of 17 Old 02-09-2018, 05:46 AM Thread Starter
Pmedic920's Avatar
Thank yall so much for the replies.
I appreciate all.
post #8 of 17 Old 02-09-2018, 06:20 AM
tapcola's Avatar
Take a look at the new TRE block .all composite.
SYNERGY, FOX,VKS,HUTCHINSON,
tapcola is offline
post #9 of 17 Old 02-10-2018, 02:02 PM
gt1guy's Avatar
A mutha fucking tactical snatch block. Who'da thought.
Looks too good to use.
Kevin
gt1guy is offline
post #10 of 17 Old 02-10-2018, 02:37 PM
Dkjeep's Avatar
OHHHH dats purdy
Dkjeep is offline
post #11 of 17 Old 02-10-2018, 06:50 PM
I have a pair of these in my recovery kit . I have hooked them up to an immobile Trac loader before and pulled an xj that was buried over it's roof in mud out with a 9k winch runnin synthetic line before. As long as your pulley wheel is copacetic with your type of line , you'll be good.
post #12 of 17 Old 02-12-2018, 06:06 AM
And a 32,000 # limit. Interesting.
post #13 of 17 Old 02-12-2018, 06:21 AM
Iim afraid to go look at how much one of those probably costs.
post #14 of 17 Old 02-12-2018, 06:27 AM
tapcola's Avatar
Not to bad. https://tacticalrecoveryequipment.co...-snatch-block/
160 bucks .
tapcola is offline
post #15 of 17 Old 02-12-2018, 02:20 PM Thread Starter
Pmedic920's Avatar
I looked, and wont be purchasing them.
Im on a budget.
post #16 of 17 Old 02-13-2018, 05:41 AM
not as bad as Id thought. I mean, big pulley,shackle blocks are heavy , so if I were a pro crawler or technical buggy in the hammers and bein conscious of every ounce was vital I could justify the highest tech available .
post #17 of 17 Old 02-13-2018, 09:27 AM Thread Starter
Pmedic920's Avatar
Snatch Blocks ????
In that situation its probably a great option.
