Gear set material. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 02-02-2018, 05:09 PM Thread Starter
Dkjeep's Avatar
Gear set material.
I am trying to help a friend out and am looking for the most durable gear-set out there for a 44 axle. My research shows that 9310 steel is pretty much up there as far as this is concerned. The only problem is between all of the various manufacturers I cant find any in this material. All I am seeing is 8620. Any idea if JK gears even exist in 9310?
Dkjeep is offline
post #2 of 14 Old 02-02-2018, 05:47 PM
Random Dude
I don't know the answer to your question, but I'd be more concerned with the validity of the material certifications and with the process control at the manufacturer (heat treat, machining, grinding, etc.).
If you do find someone selling gears made from your chosen alloy, just make sure they didn't pencil-whip a "Alloy 9310" material certification while actually selling you shit gears made from melted down Yugo bumper brackets.
Hint: the cert. should say something like
"Chemical Analysis per ASTM XXXX . . ."
NOT
"Deese are bestest Steel Metal of 9310 Alloys with most happy strongness and supreme durables . . ."
Not saying you shouldn't pursue a given material, just saying "trust, but verify" - mostly verify.
ExWrench is offline
post #3 of 14 Old 02-02-2018, 06:17 PM
i dunno as much as you about the material but I can tell you that Revolution Gear and Axle has both Koyo & Timken gears for Jeeps and they are straight-up , honest people that would probably be able to tell you all manner of details on material and strength , etc were you to contact them and ask. They answer all manner of questions for me & had I know that, I may have steered towards their gears but I had not experienced them at the time I upgraded lockers and R&Ps so Marcus at RCO set me up with ha great deal on Yukon R&Ps that I had cryo treated and I wring the crap out of them. ( edit: to underline that; I just had Revolution warranty-replace both rear 4340 chromo axle-shafts which I bent this past fall .Nothing as far as the R&P nor lockers nor DS's nor transferfercase (braced) felt victim to any of the impacts.
The shafts bent just before midlength, not the flanges. you'd normally think the R&Ps would grenade being my point. )
maybe reach-out to them , as well?
post #4 of 14 Old 02-02-2018, 06:23 PM
sorry. that first sentence had some freakin' run-on to it, didn't it? sheez...
post #5 of 14 Old 02-02-2018, 07:40 PM
Semi-float design can still bend the middle of the axle shaft. Don't think you bent that from torque. You'd snap a shaft long before you bent it from torque.
Here's a drawing showing the forces on a semi-float axle. Force F1 is equal to F2 in the drawing (at least approximately, this would be true for infinitely thin bearings). The green line shows what your axle-noodle looks like when under vertical load from the vehicle weight or an impact on the tire (obviously way over-exaggerated).
You would not have bent that if it was full float, almost guaranteed. Says nothing about R&P strength and everything about how crappy a semi-float axle design is for off-road abuse.
christensent is online now
post #6 of 14 Old 02-03-2018, 08:21 PM
gt1guy's Avatar
If I remember correctly, 9310 is used for drag racing gear sets and not for street use. Great for high impacts, but they don't last long.
Kevin
gt1guy is offline
post #7 of 14 Old 02-03-2018, 08:50 PM
Comfortably Numb
RubiCajun's Avatar
This may help.
https://www.makeitfrom.com/compare/N...Ni-Cr-Mo-Steel
RubiCajun is offline
post #8 of 14 Old 02-03-2018, 11:31 PM
no, I didn’t think it was otherworldly torque that did it ; it was impact all the way but some of that impact I’d have thought would have set some directional energy to the r&p / locker that was of a type or in a way that it would be broken because of. ( edit: I looked over the shafts really well after rev replaced them and just couldn’t believe that something that well designed and stout was bendable but with how you’ve just detailed the energies that are the shortcomings of semi float design bring to the table ) what I was misunderstanding . That was a good explanation. it totally makes sense .
Yeah, you’re right, the OEM axle housings and setup suck compared to full float.
That’s a lot of force but I guess oversize tires on too small semi floats and this is what happens
post #9 of 14 Old 02-04-2018, 07:11 AM
like @RubiCajun provided ( that link is awesome, dude), here is something I had bookmarked and which page 43 , but in particular page(s) 48 - 49 might be useful for OP research. It’s free to read, too.
post #10 of 14 Old 02-05-2018, 08:03 AM Thread Starter
Dkjeep's Avatar
Good info, nobody makes a thick cut set for a JK though. We've looked everywhere
Dkjeep is offline
post #11 of 14 Old 02-05-2018, 01:11 PM
gt1guy's Avatar
I bet you found a lot of 9310 gear sets for Ford 9" though.
Don't forget about benefits from shot peening, Cryo treating and REM polishing.
Kevin
gt1guy is offline
post #12 of 14 Old 02-05-2018, 01:16 PM Thread Starter
Dkjeep's Avatar
Yah, found a nutty guy who sounds totally off his rocker out in AZ who will do it all to any gearset for $550. He wants the bearings and attachment bolts as well to do.
After 30 seconds of technical jargon about how he do what he do I glossed over just said ok every brief pause in conversation. It was exactly like talking to Howe and you realize the guy is a master at what he does and you dont need to understand it because there is no doubt he does.
Dkjeep is offline
post #13 of 14 Old 02-05-2018, 01:31 PM
gt1guy's Avatar
Ya, if he's asking for the bearings and bolts, he most definitely "understands" the benefits. He sounds like one of the "just call me when you're done" kind of guys. I love them.
Kevin
gt1guy is offline
post #14 of 14 Old 02-05-2018, 05:25 PM
Cryyyy-oooo....
sílike frozen, metal donuts....gllgggg....
