shortening rock rail - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 09-20-2010, 12:17 PM Thread Starter
The Flower Guy
Tagg's Avatar
I've got 35's and finding the tires rubbing on the rockrail even with the RE short arm lift. I'm thinking of shortening it approx 2". Does it bolt on with two bolts? Has anyone cut it on an angle? It would look better but I don't know if the end-plug would still fit.
Any input appreciated.
Jim
Jim
Tagg is offline
post #2 of 7 Old 09-20-2010, 12:36 PM
scottrock's Avatar
Two big bolts & about 8 small ones.
Sawzall is your friend
scottrock is offline
post #3 of 7 Old 09-20-2010, 12:57 PM
StubEXrube's Avatar
You can cut it at a slight angle and the plugs will still fit. Sawzall or grinder- heck, you can use a Dremel if you have some time to kill, and look at cutting back the pinch seam at the same time. Rattle can any bare metal and done.
Not the best pic- but you can kind of see that mine is cut to be almost parallel with the edge of the tire. 35" tires in this pic.
StubEXrube is offline
post #4 of 7 Old 09-20-2010, 10:53 PM
Some suspension kits have longer control arms to push the rear tire back to avoid the issue. But in your case - Sawzall and you're good to go!
post #5 of 7 Old 09-20-2010, 10:55 PM
yip, that's corret on the bolt numbers for a stock Rubi rock rail.
post #6 of 7 Old 09-22-2010, 02:43 PM Thread Starter
The Flower Guy
Tagg's Avatar
Do you think bending back the pinch seam is better than cuttung it off?
Jim
Tagg is offline
post #7 of 7 Old 09-22-2010, 03:07 PM
StubEXrube's Avatar
JMO- cutting it produces a cleaner look. When you bend it, you risk cracking/ peeling the paint in a larger area, and it can distort the sheet metal. just looks cleaner imo to chop and touch-up.
