Brake lines hitting coilovers - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By TurbineGuy
  • 1 Post By thedirtman
post #1 of 17 Old 01-26-2018, 10:35 PM Thread Starter
TurbineGuy's Avatar
Im looking for a source of brake lines for my JKU. Just added coilovers an the brake lines hit the coilovers at full lock, because all the brake lines have that 90 degree banjo fitting that sticks out.
Im looking for some brake lines that have straight banjo fittings but no luck.
I tried my local hydraulic tubing shop, but they don't have the right size banjos.
Note: Prorock 44 front with JT Performance (Crown) big brake kit.
TurbineGuy is offline
post #2 of 17 Old 01-27-2018, 09:50 AM
Have you tried adding a spring on the line to keep it out of the coils? Or flipping the fitting?
post #3 of 17 Old 01-27-2018, 09:59 AM
DJ1
DJ1's Avatar
If you've got $20 to burn, Teraflex has those Brake Line Anchors that came out sometime last year I believe.
TeraFlex 1101255 JK Front Brake Line Anchor
I don't run them though since I've been good with my front setup...
DJ1 is offline
post #4 of 17 Old 01-27-2018, 10:57 PM Thread Starter
TurbineGuy's Avatar
Its not the lines, its the actual fitting.
Flipping the fitting would just put it oriented into the tire.
This aint mine... but the same kit, and you can see how they are oriented.
Found a thread on wrangler forum where the same issue is discussed. I think mine is even worse because of the coilovers.
post #5 of 17 Old 01-28-2018, 08:37 AM
By flipping I meant having the fitting pointed down not towards the tire.
post #6 of 17 Old 01-28-2018, 08:47 AM
tapcola's Avatar
Not to derail things , but are you running the stock MC with that Crown kit ?
SYNERGY, FOX,VKS,HUTCHINSON,
tapcola is offline
post #7 of 17 Old 01-28-2018, 09:17 AM Thread Starter
TurbineGuy's Avatar
Yes. for now. No problems.
tapcola likes this.
post #8 of 17 Old 01-28-2018, 09:18 AM Thread Starter
TurbineGuy's Avatar
Fittings are rectangular. Not enough room to flip them 90 degrees. Can only flip 180 degrees.
post #9 of 17 Old 01-28-2018, 10:55 AM
You can bend the hard lines some. I have bent my rears for clearance and haven’t had any issues.
In your case it appears if you bent them up and towards the rear of the Jeep (like 45* and 45*) that they would clear the bottom mounts.
Biginboca is offline
post #10 of 17 Old 01-28-2018, 01:40 PM
Right that was what I was talking about and you can do 90 degrees if you want it just takes a bit of grinding to gain the needed clearance. Are you running coil overs and bypasses or just coil overs? I would question the lower mounts if just running coil overs.
post #11 of 17 Old 01-28-2018, 03:53 PM Thread Starter
TurbineGuy's Avatar
Its a standard Prorock 44. I think the combo of the brakes, coilovers and Prorock are just an unlucky combo.
Im going to try teraflex lines, they have round banjo fittings, and the bend is shorter.
Not really wanting to bend lines or grind bolt... Im a bit conservative when it comes to brakes.
post #12 of 17 Old 01-28-2018, 04:08 PM
Its likely the lower mount being in a bad spot like the back of the axle where it should be on the top of the axle tube if you are just running a single coil over shock. The reason the fittings are square is because it keeps the fitting from spinning and coming loose where a round one will can. The rectangle block is solid and can easily be ground so it is round as long as you don't get into where the brass seals are. It is a simple 5 minute job that saves you $100 but whatever. I am surprised the shop you have it at simply did not bend them as they are a rather soft material and bend easily or flipping it 180 as it would lower the brake line by 4" and make it easier to bleed.
ChuckTheRipper likes this.
post #13 of 17 Old 01-30-2018, 10:57 AM
jhubright's Avatar
I'm no brake expert but something seems to be wrong with your 90 degree fitting. I've never seen an install with the fitting facing out. Facing it out seems to be a recipe for disaster. It has more potential to get hit. On almost every install the 90 degree fitting usually faces upward. Maybe they sent you the wrong brake lines.
Just a thought!
jhubright is offline
post #14 of 17 Old 01-30-2018, 04:10 PM
Just a thought!
yeah, OEM are gonna have the neat, tidy little fittings that sit flush to the side but many if not most large, aftermarket brake kits or solutions from aftermarket are like this
and the OPs.
there is another thread that @SoK66 has active right now talkin about this I believe....
post #15 of 17 Old 02-06-2018, 06:19 AM
tapcola's Avatar
You could just move the line to the other side of the shock .
tapcola is offline
post #16 of 17 Old 02-06-2018, 07:25 AM
Rubi-8's Avatar
In the Project-JK picture, they have the brake lines swapped from left to right. I have seen this a few times. The hard line portion should be right up against the caliper. Just removed my axles otherwise I would take a picture.
Another complication is using the Teraflex brake calipers where the lines mount to the top rather than the sides. The Dirtman is correct in a little reshaping of the fitting would work and swap the lines from left to right so the hard line it facing up and will stay out of harms way.
07 JK-8
08 2dr Sahara
17 Gobi Recon
Rubi-8 is offline
post #17 of 17 Old 04-10-2018, 09:04 PM
I just did the Crown Automotive BBK install and did a little mod to make my Metalcloak lines fit. I set the caliper up in my milling machine and just took a little (about .075") cut off the back of the pad where the brake line block mounts. It allowed me to spin the orientation of the block so the line points up. It flexes like it should when you turn the wheel right and left. Super easy to setup in a milling vice if you have access to a mill.
RTillery is offline
