Poison Spyder C-pillar support install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 01-25-2018, 03:02 PM Thread Starter
It's always bothered me that the JKU had no additional support between the B-pillar to the rear portion that tie into the tub. I happened to come across the Poison Spyder C-pillar support while browsing around. For the price and the ease of install, it was a no-brainer. Was also a nice little welding project to practice welding cage tubing. All joints were TIG welded. this is my first time welding a cage, so my welds arent perfect.
MISHIMOTO IS JUNK
chknkatsu is offline
post #2 of 9 Old 01-25-2018, 09:23 PM
gt1guy's Avatar
That brace is a damn good idea and much needed. Welds look fine, no undercut, no cold lap. Quality.
Kevin
gt1guy is offline
post #3 of 9 Old 01-26-2018, 05:54 AM
Cod
Cod's Avatar
Send a message via MSN to Cod
Same, I added it a while back. Nice welds!
If you want something to cover them up I believe the YJ Cage door padding fits those quite nice and you can pick them up for just about nothing. I have purchased them but the hard top is still on and I'm not fighting putting them on until soft top goes on.
Cod is offline
post #4 of 9 Old 01-26-2018, 06:09 AM
Looks great man. I will be doing this soon as well. I have a PS cage and the c pillar support ready to go in this spring. Nice thing about tig is, if it looks good it more than likely is good, as compared to mig (can look great but may not have any penetration).
18 JKU Granite Crystal- 4"lift, 40s, UD60s
07 Red Rock Crystal JKU - Sold
RedRock0740 is offline
post #5 of 9 Old 01-26-2018, 06:22 AM
nicely done .
I, too, have just this past year been looking at the same supports ...I think I was looking at Rockhard 4x4s as I was scanning for the new crossmember I require. Theirs looks exactly the same as the PS, if I recall correctly...at any rate, you did a nice job .
What amount of total weight was added, if you know, from those two supports?
post #6 of 9 Old 01-26-2018, 01:03 PM Thread Starter
nicely done .
maybe 20lbs? not a significant weight increase at all. especially considering what it does
Sent from my SM-G930V using Tapatalk
MISHIMOTO IS JUNK
post #7 of 9 Old 01-26-2018, 01:05 PM Thread Starter
thank you. not concerned about any sort of cover. its a trail rig and my backseats have been long gone
MISHIMOTO IS JUNK
post #8 of 9 Old 07-18-2018, 04:47 PM
Hullerman's Avatar
[QUOTE=chknkatsu;4356329][quote=Cod;4356081
Sent from my SM-G930V using Tapatalk[/QUOTE]
Did you weld it up first or bolt the bottom in first?
What were the clamps on the tube and base for in the one pic?
Bug counter
Hullerman is offline
post #9 of 9 Old 07-24-2018, 09:23 PM Thread Starter
[quote=Hullerman;4430110]
bolted the base first, lines the tubes up and welded it.
clamp is so i had something to clamp my ground to
MISHIMOTO IS JUNK
