Running the stock BCM stand alone?? - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By KOWBOY
  • 1 Post By 0lllllll0 RPMEXTREME
post #1 of 11 Old 01-23-2018, 08:49 PM Thread Starter
Frozen North's Avatar
Looking at different options for my pile of JK. Obviously everything is connected via CANBUS. Is there any way to run the BCM stand alone, without the ECM? I assume not, but I want to make sure I check it off my list of things I cannot do with the factory wiring. I am looking at engine options, but am not willing to spend 15k plus for an LS swap (after tranny and t case and wiring etc). Thanks for reading my stupid question. Lol
Your lack of commitment disturbs me...
President of Alaska Extreme Frouwheelers club
Frozen North is offline
post #2 of 11 Old 01-24-2018, 06:39 AM
15k would be cheap for a well done LS swap in a jk by motech or RPM Extreme .
Id go so far as to say if you are not in a position to spend at LEAST 15grand, you maybe better off saving a bit longer. Or, just swapping a stock motor in with low miles and SC it.
I dont know much about that engine management- BCM - you ref but if you wanna check some tech nerd CAN hacks , this guy was doing them to his 13 JK early in his ownership. It is such an integrated bus for the required data to cintrol everything that you basically have two choices : stick with it and go with a kit and use the support that it offers to work yourself thru the swap OR gut the entire vehicle and rebuild every single gauge and system monitor and control like you would a buggy. Check out @KOWBOY thread on here about his Turd .
post #3 of 11 Old 01-24-2018, 07:44 AM
ALASHA's Avatar
Doesnt the @0lllllll0 RPMEXTREME kit run the BCM standalone?
ALASHA is offline
post #4 of 11 Old 01-24-2018, 10:48 AM
KOWBOY's Avatar
... OR gut the entire vehicle and rebuild every single gauge and system monitor and control like you would a buggy. Check out @KOWBOY thread on here about his Turd .
'Preciate the call out.
But reckon it's a good bet most folks ain't wantin' to go to the extreme I am in order to get shed of the 'lectrical problems.
j3ff3ry_j33p likes this.
My Trailer Queen don't ride on one ... it pulls one.
KOWBOY is offline
post #5 of 11 Old 01-24-2018, 10:57 AM
0lllllll0 RPMEXTREME's Avatar
No. We don't run a GM BCM. We have a EZcanbus module that takes care of all the CAN messages and does the job of the GM BCM.
You could run a gm BCM on a standalone harness and get the TAP shift and cruise to work but it would take a ton of work and still wouldn't help you integrate it into the Jeep side.
The best bet is to just go with our Base DIY kit. That will give you all the wiring-canbus as well as the mounts etc... to get it into the Jeep and running with all the options working like factory.
You can then source all the extra stuff yourself.
post #6 of 11 Old 01-24-2018, 11:03 AM
gt1guy's Avatar
Probably a dumb question but, the Jeep has no BCM correct?
Or is that basically what the TIPM is?
Kevin
gt1guy is offline
post #7 of 11 Old 01-24-2018, 12:36 PM
ALASHA's Avatar
Thought the Jeep does have a BCM and I wasnt saying to run a GM BCM standalone. I was saying to run the Jeep one without getting signal from a Jeep ECU since it would be gone and replaced by a GM one.
ALASHA is offline
post #8 of 11 Old 01-24-2018, 06:27 PM
There is nothing called a BCM on the Jeep side. I would say the TIPM and CCN (cabin compartment node) "cluster" would be the body control module of sorts.
And no. you wouldn't be able to run the Jeep TIPM standalone and expect much of the Jeep to operate.
With the technology of the conversion kits you would be crazy to try run standalone unless you plan on gutting the entire Jeep electronic system and going full standalone everything buggy style
I know it comes down to cost and time. You either pay now and have a working jeep conversion in a week or mess with it trying to make everything work and end up paying double later.
post #9 of 11 Old 01-25-2018, 01:35 PM
gt1guy's Avatar
I think it was Robbie who had been using GM BCM's in the mix at some point, or maybe still does, who knows, it never seems like any two of his kits are the same.
Jon,
What is the CCM "cluster"?
Kevin
gt1guy is offline
post #10 of 11 Old 01-26-2018, 09:05 AM
Jon,
Cabin Compartment Node (CCN). Basically its the instrument cluster. It sorta does the same thing as a GM BCM in a way.
post #11 of 11 Old 02-17-2018, 05:52 PM
MoTech's Avatar
We've been ruining BCM's since 2007 in Gen IV swaps but we have not run a BCM without an ECM.
Of coarse we can run without a BCM and get all the functions like Tapshift, CC.... using CAN but we still run BCM's in some swaps.
Recently I butted heads with the BAR in California, let's just say my fight went from the Referees to the Regional Managers to the Senior Engineer of the BAR to the Chief of the BAR. Then it went to the department of consumer affairs(DCA oversees the bureaus) and stopped short of going to the AG(Attorney General).
Bottom line is we got the BAR to the negotiating table and challenged their unfounded claims.
The BAR had to recognize our conversion is different. They challenged the harness, calibrations, modules and said they needed EO's, but they don't because they are OE and approved by the USEPA. All the crap you guys hear me talk about OE harness, power distribution, blah, blah, blah..... this is where it matters, these guys look for it.
We are currently required to run a BCM in CA or get an EO on the CAN interface with the ARB. Of coarse we are working with the ARB but it takes time so whenever you can use unmodified OE components the better.
MoTech
725-502-8507
MoTech is offline
