Detroit in front - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 09-19-2010, 12:45 PM Thread Starter
BADGER's Avatar
Detroit in front
Anyone running one? My Heep isn't a daily driver, but I do drive it back and forth to the trails in the summer. I don't want one in the rear (selectable is better here) because of the street time and maneuverability on the trails. But I think I'd be golden with one in the front, I don't see much of an issue with one on the pavement. It would be nice to have one up front and just not worry about it....
Thoughts?
-Milton Friedman
BADGER is offline
post #2 of 17 Old 09-19-2010, 12:59 PM
SoK66's Avatar
Not unless you go with some form of manual hub up front to disengage it. Plus, you'll need some help in the steering boost department, the stock pup & box aren't going to be up to it. Unless it's a very heavily beefed up trail rig, better to go with a manual locker up front. JMHO, of course.
SoK66 is offline
post #3 of 17 Old 09-19-2010, 01:03 PM
I'd put one in the rear before the front. It'll just bury your turning radius off road. And forget using it in the snow in 4-hi
post #4 of 17 Old 09-19-2010, 01:07 PM
2k2wranglerx's Avatar
you could try an aussie or lockrite up front rather than a full on detroit...
i'm n ot a huge fan of a front auto locker, but they work great. they're just quirky on the road (in the snow) but since you're not daily driving the jeep i think you'd be fine.
as far as on the trail. you won't be able to turn as sharp that's for sure, but you won't have any problems turning the steering wheel... no more than you would normally. it's not like you're spooling it.
2k2wranglerx is offline
post #5 of 17 Old 09-19-2010, 03:28 PM
Living Still's Avatar
This is a questions that comes up pretty regularly... There are plenty of people who run detroits front and rear and seem to just fine on and off the road. You just have to be careful and pay attention, especially in the ice! As far as putting one in the front or rear the consensus among the Jeep daily drivers out there is that it is better in the rear. If you go onto Pirate4x4 and digging around all posts that cover this same topic.... you will get the opposite answer. It's hard to give a good answer there. A few of the competitors on Pirate seem to think that a detroit front and an ARB rear is better than the other way around. I think their explanation was something along the lines of the back of the car "pushing" the front end around. So in short... I really have no idea lol, but there is quite a bit of ambiguity thats for sure.
~Casey
Living Still is offline
post #6 of 17 Old 09-19-2010, 04:34 PM
For a DD in Denver, a Detroit up front wouldn't be my first choice.
But for your situation - not your DD, and driving in 2WD to the trails in the summer? Go for it! (just remember that it's up there when you leave your car in the garage and drive the Jeep to work during the snow/ice storms... )
GreenJK is offline
post #7 of 17 Old 09-19-2010, 04:59 PM
I have Detroits front/rear. No issues. You need to drive it like a Jeep, period.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #8 of 17 Old 09-19-2010, 06:55 PM
desert dog's Avatar
Actually, I believe its just the opposite. The Detroit in the front lets you keep your turning radius, its that rear Detroit that kills you in the technical stuff. Many competition crawlers, including the Curries, run a Detroit in the front and selectable in the rear. I have not lost any turning off-road with my front Detroit. In the technical stuff, my rear locker almost never gets used. But, having said that, guys running dual Detroits go through the same stuff I do and have little trouble (except for the occasional 3-point turn).
As for street driving, I have driven on the street several times with my hubs engaged in 2WD, and the difference is slightly noticeable. It's not bad at all and not noticeable most of the time, just much better doing u-turns and parking with the hubs unlocked.
I agree with the Denver comment; Detroit probably not the best option for your location. I run mine in the snow and it does great, but on ice, I unlock those hubs and stay in 2WD. In winter, you probably deal with ice daily.
desert dog is offline
post #9 of 17 Old 09-19-2010, 07:09 PM
JKSteve's Avatar
On my last Jeep I ran one in the rear with a tru trac LSD up front. This combo was great on and off road. Snow, ice, dry, whatever. I don't think a rear one hurts turning at all, but seems like the front really would.
LJ Rubicon
JKSteve is offline
post #10 of 17 Old 09-19-2010, 07:34 PM
desert dog's Avatar
Think of it this way;
With the front locked up and the tires turned, the jeep is pulled in the direction that the front tires are pointed. Either straight, right, or left. Maneuvering on the trail is often made easier with that Detroit up front. As a matter of fact, most comp rigs in really tight spots completely disable their rear axle (sometimes braked and sometimes free-spinning) with the twin stick and lock in the front only; this is called a "front dig" and lets them turn on a dime.
With only the rear locked up, both rear wheel are pushing the direction that the tires are pointed, straight ahead. This makes turning difficult, especially in rocks.
Most competition crawlers or folks that run the technical stuff will confirm this.
post #11 of 17 Old 09-20-2010, 04:44 AM
levellinebrad's Avatar
I put a power trax up front and do not notice it at all on the road. Off road it makes a tremendous difference in how it steers but only while the fronts are digging. After climbing a steep hill or navigating a rocky path, I will switch back to 2 wheel drive for for going to the next obstacle.
levellinebrad is offline
post #12 of 17 Old 09-20-2010, 07:55 AM Thread Starter
BADGER's Avatar
Cool - good information here. Remember ice and snow are a non-issue; I've got a Subaru for that. I don't winter-wheel either (I hate that shit). It's only driven in nice weather, and to and from the trails.
Desert Dog - you running the Spyntec kit? I like the idea, but it looks like I'd have to give up my RCVs and go back to u-joint axles, which I really don't want to do.
-Milton Friedman
BADGER is offline
post #13 of 17 Old 09-20-2010, 08:32 AM
Joneszj's Avatar
I run an Aussie and it kicks ass. It was cheap and it does the same thing as the expensive lockers. I've gotten to try it out a few times since having it installed and damn is it a difference. Over time the lunch box style lockers may wear out, but its alot easier to replace the little springs than a new locker. I love it
1972 Commando on Tons & 40s
Joneszj is offline
post #14 of 17 Old 09-20-2010, 09:06 AM
the reason they run an ARB in the rear is for cutting brakes...
after running a detroit up front i have to disagree. that thing turned like a boat. had to pop it into 2low to turn half the time.
on the tough technical twisty stuff it was fine, it was the tight trails getting to the obstacles where it SUCCKKEEEDDD
post #15 of 17 Old 09-20-2010, 09:45 AM
desert dog's Avatar
No. Running a Rock Jock 60 with manual hubs.
post #16 of 17 Old 09-20-2010, 10:50 AM
Dynatrac's Avatar
Detroits work fine in a front axle. If you're worried about steering pump and box issues with them, you'd really hate it when a selectable is locked. A Detroit Locker equipped rig turns much easier than a locked selectable. That said, I like to upgrade steering boxes and/or pumps whenever front lockers are in play.
For me, one of the best investments I ever made was a t-case with a twin stick. Once you've done a front dig, you'll never go back. Doing a new t-case isn't a cheap mod but it will grow with your rig. It's one of the few mods that you can keep throughout the life of your rig. In the tight twisty trails, regardless of your front axle locker choice, front wheel only makes a huge difference.
Dynatrac is offline
post #17 of 17 Old 09-20-2010, 10:58 AM
I agree 100% my ARB switch shorted out on our last trail ride and i was HATING life. not being able to turn sucks!
and a twin sticked case is definitely the shit
