broke my rear track bar - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 09-18-2010, 09:21 PM Thread Starter
jaker's Avatar
broke my rear track bar on my 2wd
well it finally happen , it took me a day to find out what was broke , but here it is , called up http://ssfabrication.shutterfly.com/ and he had it fixed the next morning for me .
it was crack on the otherside to
he made me a bracket
jaker is offline
post #2 of 11 Old 09-19-2010, 09:52 AM
BADGER's Avatar
Typical stuff there....but glad you managed to get it fixed without having a nasty incident on the road!
-Milton Friedman
BADGER is offline
post #3 of 11 Old 09-19-2010, 09:54 AM
Dang. Those raised brackets without gussets or a u-bolt mount shouldn't be allowed!
post #4 of 11 Old 09-19-2010, 10:32 AM
BadAssJK's Avatar
Thats for sure, those brackets put so much extra stress on the already crap factory mount. I would also ditch the bracket and get an adjustable Track Bar. JKS is nice and a little over $100 I believe.
BadAssJK is offline
post #5 of 11 Old 09-19-2010, 10:50 AM Thread Starter
jaker's Avatar
I am now , didn't really think about it till it broke , so now I am looking into it
jaker is offline
post #6 of 11 Old 09-19-2010, 11:01 AM
Constantine's Avatar
Feedback: 15 reviews
Yeah in preperation of installing my Rancho lift I ordered JKS frt and rear adjustable trackbar and Poly flip kit and upper frt trackbar brace. Look like I may need to look into a rear lower brace also. Going to install next weekend I hope!
2014 JK Anvil
"If You Don't Stand For Something, You'll Fall For Anything"
Constantine is offline
post #7 of 11 Old 09-20-2010, 11:19 AM
Have you looked @ using our rear track bar bracket?
LINK
This would keep that from happening again.
Thean Bellocchi
Poly Performance Inc.
Sales & Tech Support
805-783-2060 Ext. 200
crusty1007 is offline
post #8 of 11 Old 09-20-2010, 11:46 AM
2k2wranglerx's Avatar
LINK
I like the u bolts.
any advantage over using this vs a JKS adjustable? i know AEV claims that raising the rear track bar improves handling...
2k2wranglerx is offline
post #9 of 11 Old 09-20-2010, 09:18 PM
The roll center is in fact improved.
Beyond that, the Poly Performance Track bar bracket is reinforced to better support the side loads that the stock brackets where not designed for. When you relocate the track bar mounting location up higher, it is adding more leverage & without reinforcment or gusseting, you have seen the outcome first hand.
Thean Bellocchi
post #10 of 11 Old 09-20-2010, 10:00 PM
so how does it affect handling though? does it now roll less? does it change how the jeep rolls?
post #11 of 11 Old 09-20-2010, 10:11 PM
It raises the roll center of the vehicle, causing it to not want to lean when manuevering quickly. It will handle more like stock when lifted VS. leaving it mounted in the stock axle location. The axle will also shift side to side less as it cycles through its travel because the trackbar is not already @ a harsh angle.
A better explanation of roll center: http://en.wikipedia.org/wiki/Roll_center
Thean Bellocchi
