3.6L Auto 2000RPM Hiccup in 1st Gear - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 12-31-2017, 08:13 PM Thread Starter
This has been a problem for a long time. Maybe forever. This could just be some weird software bug for all I know, wondering if anyone else has experienced it.
When I am manually shifting, when I start in 1st gear and give light-moderate throttle at 2000RPM it'll just very briefly hiccup and you feel a brief reduction in power. You can actually see the RPM needle drop down to about 1950RPM for maybe a quarter of a second. Then it goes on normally. Just happens once on some accelerations from a stop. Does not happen in any other gear, just 1st. Does not happen for heavy throttle accelerations. The effect is really very minor, a passenger wouldn't even realize it happened, and I'd have no problem accepting it if someone said "that's normal" (except if the dealer was the only person saying that ).
Is this something anyone else has experienced? Is there anything you'd suggest I look at? No CEL or codes being thrown. I had a cylinder 6 misfire check engine light a while ago and haven't since (although I did have the cylinder misfire code again but it didn't trip a CEL). No idea if that's related to this, sort of doubt it as this only happens in 1st gear.
christensent is offline
post #2 of 2 Old 01-01-2018, 12:59 AM
Rb6700's Avatar
I've never really noticed anything while manually shifting especially at a low rpm. I don't think you have an issue though.
Rb6700 is offline
