MANUAL TRANS-PLANT - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 12-31-2017, 12:04 PM Thread Starter
Question MANUAL TRANS-PLANT
Looking down the road, do you gurus see any reason why the new JL Aisin D478 manual transmission could not be easily mated to a 3.6 Pentastar in a JK/JKU?
From Jalopnik:
https://jalopnik.com/the-2018-jeep-w...ett-1821160227
"The Aisin D478 manual transmission comes with a granny-like 5.13:1 (up from 4.46:1) first gear ratio; when mated to the 4:1 low-range gear and the 4.10:1 axle ratios found in the Rubicon, that yields a crawl ratio of over 84 (up from 73)."
Can't wait to see what the input torque rating is as well. Looks like a step-up from the NSG370.
2013 JKUR
Magnuson Supercharger (66mm Pulley) with Catch Can
Innovate Wide Band O2 Sensor
Diablotoona Custom Tune
Volant Cold Air Intake
6-Speed MT with B&M Precision Sport Shifter
4.10 Rear Diff
Line-X of Interior and Rock Hard 4x4 Sport Cage
JW Speaker Headlights, Fog Lights, and Tail Lights
BFG All-Terrain T/A KO LT265 70 17 (actual height: 30.75")
doc5339 is offline
post #2 of 4 Old 12-31-2017, 12:26 PM
ChuckTheRipper's Avatar
I sure hope it's a direct or at least adaptable swap onto the backside of a 3.8l. I haaaaate the NSG.
ChuckTheRipper is offline
post #3 of 4 Old 12-31-2017, 06:33 PM
Not sure on direct swap. Since it will be behind the 3.6, probably can bolt up, but the shifter that is cable actuated (per reports) which makes it more difficult to go into a JK and the computer might not like the unexpected changes either.
UFDUB is offline
post #4 of 4 Old 01-01-2018, 12:33 AM Thread Starter
Good points, thanks!
2013 JKUR
4.10 Rear Diff
doc5339 is offline
