Painting stock JK wheels - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 09-16-2010, 02:12 PM Thread Starter
djlayne's Avatar
Can anyone give me any shortcuts or instructions on painting my stock JK wheels black. I've tried a search on the site and didn't really get what I was looking for. Thinking of flat black, but since I know nothing about painting can someone give me some tips. Do I need to sand off the finish and prep with any kind of primer. HELP
DJLAYNE
djlayne is offline
post #2 of 20 Old 09-16-2010, 03:27 PM
frankie945's Avatar
frankie945 is offline
post #3 of 20 Old 09-16-2010, 03:29 PM
i would just give it a light sanding, clean them, and hit em with something like krylons ultra flat camo paint. it works really well. instead of taping off the wheel at the tires bead i usually just make a curved stencil of the wheel so paint doesnt get on the tire. hope that helps.
Mt.GoatJK is offline
post #4 of 20 Old 09-16-2010, 03:31 PM
self etching primer is your friend.
post #5 of 20 Old 09-16-2010, 04:11 PM
Pedro7869's Avatar
Yes it is. I am getting ready to redo mine. I let the air out of mine and used 3x5 note cards to put under the bead, a little of newspaper and I went crazy with the spray.
My JK
2007 X Bright Silver 6 Speed 3" Black Diamond Superlift Steering Dampner Black Diamond Shocks RC 1.25" Body Lift 35" BFG MT KM2s LOD Rear Bumper/Gen 2 Tire Carrier LOD Mid Width Front Bumper W/Skid LOD Sliders Skidrow Evap Canister Skid Benchmark Oil Pan Riddler Front and Rear Diff Cover 4.88's Benchmark Dana 30 Steel Axle Tubes Alloy USA Performance Axle Tube Seal Smittybilt XRC8 (with synthetic line) K&N Air Filter AEV Snorkel Kit and much more
Pedro7869 is offline
post #6 of 20 Old 09-16-2010, 05:19 PM
I had my rims powder coated
decipher911 is offline
post #7 of 20 Old 09-16-2010, 05:20 PM
PIG
PIG's Avatar
Dude, just powder coat them...
Powder Coaters in your area
PIG is offline
post #8 of 20 Old 09-16-2010, 08:58 PM Thread Starter
djlayne's Avatar
Frankie 945
Thanks for the help!!!!!!!! Looks like something I can tackle in a weekend. If I mess them up I haven't got a lot of money in them so I can just do it again. Thanks again for everyones input.
DJLAYNE
djlayne is offline
post #9 of 20 Old 09-16-2010, 09:09 PM
I did my OEM sahara rims and am really happy with them.
all of the action is in the prep. If ou take your time with the prep, your coating will look fantastic and not peel off. I stripped off the factory coating with a scouring pad hooked up to a drill (worked much better than wet sandpaper). Take your time stripping all of the coating. clean the wheels with soap/water and let them dry. Use a solvent and rub it off to make sure there is no oil on them. Tape off the wheels with painters tape and use acid etching primer. Spray on lots of really light coats to make it look better (e.g. 5 coats). After that, spray on whatever you want (lots of light coats again to make it look and stick better). I used rustoleum hammered metal black paint and it looks great! It's more of a really dark titanium than black. I've had some really good run ins with trees and rocks with this coating and the paint sticks on better than the factory coating did. The good thing about the hammered metal coating is that when you do scrape them up, you can just re-spray them and the blemmish is gone. It took me two days.
Bone206 is offline
post #10 of 20 Old 09-16-2010, 09:25 PM
Ballpark, how much would power coating them cost?
aristobrat is offline
post #11 of 20 Old 09-17-2010, 09:52 PM
fourplyn's Avatar
You can get this most anywhere..or just go to http://www.eastwood.com/
Cost's about $10-20 a wheel to have them sand or bead blasted (which has to be done prior to powder coating)
Powder coating cost's $40-$60 a wheel.
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #12 of 20 Old 09-18-2010, 11:02 AM
2010jk's Avatar
Yep what goodysgotacuda said, its a good idea I used it.
2010jk is offline
post #13 of 20 Old 09-18-2010, 11:18 AM
gold knight's Avatar
This is still my favorite because it breaks up the tire and wheel so it doesn't look like one black disc. You may or may not like it, kind of personal preference.
gold knight is offline
post #14 of 20 Old 09-18-2010, 02:39 PM
2010jk's Avatar
I got the idea from venom, I just need some tire's.
2010jk is offline
post #15 of 20 Old 09-18-2010, 02:41 PM
HOOLIGAN's Avatar
I dig that!! Is that just Duplicolor?
HOOLIGAN is offline
post #16 of 20 Old 09-18-2010, 02:42 PM
2010jk's Avatar
2010jk is offline
post #17 of 20 Old 09-18-2010, 02:44 PM
2010jk's Avatar
yep
2010jk is offline
post #18 of 20 Old 09-18-2010, 03:27 PM
Walmart has duplicolor or rustoleum self etching primer in a rattle can in the automotive section. By touch up paint.
post #19 of 20 Old 09-18-2010, 05:02 PM
With self-etching primer, do you still need to sand/scotch-brite the wheels first?
post #20 of 20 Old 09-18-2010, 05:21 PM
Yes, you should scuff every surface before painting.
