Lockers - JKowners.com : Jeep Wrangler JK Forum
post #1 of 61 Old 09-16-2010, 12:47 PM Thread Starter
chuckanut105's Avatar
Lockers
I've found that i need locker for my X after my last wheeling experiance. I looking at either the eaton or the aburn e- lockers. Im gonna run 4.88 gears. Anyone have any experiance with either of these set ups?
09 X 3.5 rubi express on 35" KM2's
chuckanut105 is offline
post #2 of 61 Old 09-16-2010, 01:53 PM
desert dog's Avatar
Stay away from the Auburn ECTED unit. It is not known for reliability and has clutch plates that wear out. The Eaton unit is good to go. I have used mine in the rear of my little X with good results. Also consider an ARB if you would like to run onboard air.
desert dog is offline
post #3 of 61 Old 09-16-2010, 01:55 PM
RIP Brad
abendx's Avatar
Blah.... go Detroit or go home!
Although... I was pretty impressed seeing you wheel open.
abendx is offline
post #4 of 61 Old 09-16-2010, 02:20 PM Thread Starter
That sucks i likes the Idea of having a posi. I didnt know that i could get an ARB with stock axels.
Detroit no. I have had detroits before and always wanted to be able to turn it off when im on the street. As far as my wheeling ablity goes ya your just jelous of my skills.
post #5 of 61 Old 09-16-2010, 02:33 PM
Search for Dynatracs comments on lockers, (or message him), lots of good info. Very very favorable reviews of the eaton Elocker for the 30, and you don't have to mess with compressors and air lines.
Here is an excerpt from one of Dyna's posts:
The Eaton ELocker is right up there with ARB with their Dana 30 (and 35) model but the ELocker has an edge due to its 12V actuation. Testing has shown the ELocker to be equal to ARB in strength and ease of actuation.
In the selectable locker catagory the ARB and the Dana 30 ELockers are the best options.
For the rear, Dyna does not have a high opinion of the D44 Elocker, so maybe look at something else...
And Dyna's opinion on the ected while I have that one open:
The Auburn Ected looks great on paper but the actual function is poor when compared to the others. This unit is based on a clutch driven limited slip design and doesn't truly 'lock'. When 'locked', extra pressure is given to the clutches and it will act locked unless there is enough engine torque and traction to overcome the clutch pressure. Additionally, over time, the clutches will wear and lock up will be even less effective. If that wasn't bad enough, the internal side gear design has very little axle spline engagement in the LSD mode and axle shafts have been getting the splines stripped. Auburn is working on a new Ected model that is said to address these issues.
GreenJK is offline
post #6 of 61 Old 09-16-2010, 02:35 PM
RIP Brad
abendx's Avatar
I am jealous of the skills guys rolling around in H2s have... so don't feel special.
Why are worried about turning it off? The Detroit is bulletproof and you never have to worry about turning it on or off.
abendx is offline
post #7 of 61 Old 09-16-2010, 02:42 PM
SONIC's Avatar
Yes but every ride that i have ridden in with a detroit you can tell its there even when its unlocked. And try driving in the snow lol
-Doc Holiday
SONIC is offline
post #8 of 61 Old 09-16-2010, 02:54 PM
RIP Brad
abendx's Avatar
I think the snow issue is over played.... but yes, it can be an issue. The OP lives where there is no snow, so it's not really an issue.
The new soft locker is mostly seamless, an occasional pop, but not often. I have Detroits in my CJ and have had them in many other vehicles from the past and can't tell they are there.
abendx is offline
post #9 of 61 Old 09-16-2010, 03:06 PM
Run Detroits and call it a day. I have Detroits front and rear and have ZERO issues driving on the street.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #10 of 61 Old 09-16-2010, 03:10 PM
Bubblegoose1's Avatar
I'll be doing the same, at 60s time. Why rely on switches and hoses???
Bubblegoose1 is offline
post #11 of 61 Old 09-16-2010, 03:16 PM
bubba2u's Avatar
ok so who knows of a lunch box locker for the rear jk d44.
bubba2u is offline
post #12 of 61 Old 09-16-2010, 03:29 PM
fishinmagician's Avatar
I can be no help on what to choose but i hear you on the NEED for lockers. The lack of l of lockers recently led to a near death experience. They are a must for the jeep owner that does real wheeling. I almost flipped my rig...long story. Basically got too big for my britches. let us know what you decide and how it works. I will be looking to re gear and add lockers in the spring. Im leaning towards detroit lockers for the simpicity of the product, no air etc. These are the posts i follow because i am in the same situation. Good luck
George, P.I.
fishinmagician is offline
post #13 of 61 Old 09-16-2010, 04:15 PM
I keep it simple and stout. Detroits.
I don't want to rely on switches, relays, hoses, clutches, compressors, connectors, yada yada yada.
I know it's locked, and that's that.
Don't go with a lunchbox. It does "act" like a Detroit, but, eventually you're case will spread and the lunchbox will fail. Or, the lunchbox itself will fail. I have seen TOO many lunchboxes grenade. I've seen TOO many ARBs not engage due to air problems (ie. broken lines, compressor not going on, etc. I was opted to run a Spartan up front and a Detroit in the rear. Before even installing the thing, the Spartan locker's case tolerance was too tight. Tried saving $250 and the thing wasn't even installed yet and had problems. Went with a full case locker, a Detroit.
NOVA4x4
post #14 of 61 Old 09-16-2010, 05:14 PM Thread Starter
OK I might put a detroit out back. I dont know ill have to check the pricing. Ive driving in the snow with a detroit and well let just say that was "fun". Yes I dont like in the snow but I do snow board and hunt so snow is going to be ever present and besides its a jeep who knows where i want to take it. Any word on the OX lockers I know they had a bad rep for awhile.
post #15 of 61 Old 09-16-2010, 05:18 PM Thread Starter
If you love detroits so much then why dont you have them? Ill buy your lockers.
post #16 of 61 Old 09-16-2010, 05:26 PM
2k2wranglerx's Avatar
click BANG pow click click click click "WOAH"
what you hear and then say as your rig understeers on on ramps and then oversteers when you get off the gas (with a rear detroit).
i like detroits, but given the option i go selectable all day... after wheeling a rig with detroits front and rear and wheeling my rig now with ARB, ARB hands down is the way to go (or selectable). no more crappy turning radius, no more funny handling (although LWB like an unlimited negates some of the on road handling issues)
also, the rear tire wear with a detroit is pretty bad. i was suprised how fast i started burning through tires being locked in the back.
good luck with whatever you buy. keep in mind detroits aren't indestructible. they don't do well with shock loads at all. lots of people break front D60 detroits when their hubs break.
2k2wranglerx is offline
post #17 of 61 Old 09-16-2010, 05:45 PM
RIP Brad
abendx's Avatar
Does Detroit make a locker that fits in a rubi axle?
abendx is offline
post #18 of 61 Old 09-16-2010, 05:51 PM
No. Only option is the ARB 35-spline unit.
NOVA4x4
post #19 of 61 Old 09-16-2010, 06:03 PM Thread Starter
thats why im probally gonna go with the e-lockers just for compatability.
post #20 of 61 Old 09-16-2010, 06:08 PM
RIP Brad
abendx's Avatar
You have the little one up front, right? There might be more options for you than me.
abendx is offline
post #21 of 61 Old 09-16-2010, 06:23 PM Thread Starter
No cause if i get seletables i then have an excuse to get 12volt guys switch pod
post #22 of 61 Old 09-16-2010, 06:27 PM
RIP Brad
abendx's Avatar
I kinda like my sPod... much prettier in my opinion.
abendx is offline
post #23 of 61 Old 09-16-2010, 07:28 PM
Constantine's Avatar
Feedback: 15 reviews
I am also getting ready to regear my rig to 5.13 and want to add lockers. I am looking at the Eaton E-lockers but am going to look at the detroit also.
As far as lunch box lockers go I have read that they are not recomended for anyone running over 33" tires and even then they will be worn out in a year or so.
2014 JK Anvil
"If You Don't Stand For Something, You'll Fall For Anything"
Constantine is offline
post #24 of 61 Old 09-16-2010, 09:39 PM Thread Starter
No the craftsmanship that goes in to 12voltguys stuff it what i like. The S-pod is just a chunk of plastic with some switches. Sorry just my thoughts. Plus i can get it set up how i want it like burger king.
post #25 of 61 Old 09-16-2010, 10:26 PM
what crackhead told you that? i beat the PISS out of my D44 lockrite with 38" tires and it never broke.
whoever told you that is full of shit. the worst thing you'll have to do is go through the springs and pins when they wear out. it's like 8 bucks.
