Source For Shouldered Track Bar Bolt? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 09-15-2010, 08:22 PM Thread Starter
SoK66's Avatar
I'd like to replace the OEM track bar bolts on my JK with proper flanged head shouldered bolts. AS has been pointed out a few times on the Forum, Jeeps OEM bolts aren't shouldered and contribute to the process of ovaling out the mounting holes. Started searching online for M14 10.9 grade shouldered bolts and came up fairly blank. Anyone have an idea for a source?
SoK66 is offline
post #2 of 11 Old 09-15-2010, 09:03 PM
wsoffroad's Avatar
Feedback: 12 reviews
Have you tried Fastenal?
Rock Krawler, Poison Spyder, Rigid Industries, Currie and more.
OR CALL 813.361.0869
wsoffroad is offline
post #3 of 11 Old 09-15-2010, 09:06 PM
bodyguy's Avatar
a little drilling and a 9/16 will fit plus you will have better luck finding a bolt with more shoulder. buy the bolt longer than what you need and cut it, this will allow you to have a shoulder all the way through the bracket and just use a thick washer to allow for proper tightening.
bodyguy is offline
post #4 of 11 Old 09-15-2010, 10:49 PM
Mc Master Carr. They have EVERYTHING, known to man.
Hardcoreheath is offline
post #5 of 11 Old 09-16-2010, 12:52 PM Thread Starter
SoK66's Avatar
Well, found a shouldered bolt at the local Ace Hardware store that may work fine. Grade 10.9 M14x80mm, but coarse thread and no flanged head. Was able to get a flanged headed nut for it, but not with interference thread. I'll give it a go and see how it works.
If you take a close look at the frame bracket hole, the threads on the OEM bolt act like a file on it. Easy to see how the hole gets wallowed out.
SoK66 is offline
post #6 of 11 Old 09-16-2010, 01:37 PM
jsherm01's Avatar
I used one of these bolts. Threads galled and I had to cut the damn thing off. Not fun. I advise fine threaded bolt. McMaster Car suggestion was good. But they do not seem to have a any M14 bolts?
jsherm01 is offline
post #7 of 11 Old 09-16-2010, 04:19 PM Thread Starter
SoK66's Avatar
Thanks for the tipoff. I was concerned about the thread pitch, so with your experience perhaps I shouldn't try it.
Any of the usual sources, McMaster-Carr, Fastenall, etc., either don't have M14 bolts, or don't have ones that have all the attributes needed, which are M14x80, grade 10.9, flanged head, shouldered, fine thread. They'll have maybe one or two, that's it. Perhaps the tip to drill out to 9/16s is the only answer.
SoK66 is offline
post #8 of 11 Old 09-16-2010, 05:23 PM
PIG
PIG's Avatar
Another solution.
PIG is offline
post #9 of 11 Old 09-16-2010, 06:17 PM
schnauzer's Avatar
Feedback: 9 reviews
Bodyguy is right a 9/16th shouldered bolt fits, a little work is sometimes needed depending on the type of joint. i can confirm the following JKS track bars and control arms fit a 9/16th with no modifications, Rk arms and track bars require clearancing on the heim joint end, but fit just fine on the poly bushing end. for the washer on both ends i used a 1/2" grade 8 which fits on a 9/16th bolt nice and snug. finish off with a top lock nut and you are good to go. All of this can be picked up at fastenal.
schnauzer is offline
post #10 of 11 Old 09-17-2010, 07:46 PM
JDodge's Avatar
Originally Posted by PIG View Post
Wow placed an order for this like 3 hours ago and it's already shipped w/correct tracking!!!! Great Service
JDodge is offline
post #11 of 11 Old 09-17-2010, 08:26 PM
PIG
PIG's Avatar
That's how we do it dude..... Thanks for the order.
PIG is offline
