Moving front Axle forward - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 09-14-2010, 01:40 AM Thread Starter
Well as the title says i'm looking to move the front axle forward 2-3 inchs. I want to still retain the my current springs and shocks. I was going remove the front mounts and move them forward or possibly make new ones up, but that there is the least of the issues ill be coming across i guess. I am wondering what troubles will i come across with steering and panhards. have others done this what other things did you come across that had given you trouble.
thanks all for help in advance
DaveJK is offline
post #2 of 13 Old 09-14-2010, 06:39 AM
Liquor's Avatar
to my knowledge noone has done this on a JK yet. you will have to move everything forward to keep the stock steering geometry. sounds like a fun project.
something similar to what I plan on doing for the next wrangler model. a 2 door stretch with 42" tires
• Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #3 of 13 Old 09-14-2010, 07:24 AM
TrailDuty.com
PhilD's Avatar
As stated above you really need to move pretty much everything forward.
The springs will be badly bowed unless you move the upper spring buckets, there may some clearance issues with steering etc but I think you'll be okay, although relocating the track bar would be a good idea, as would shortening the sway bar arms. You'll need new control arms and most probably a new drive shaft.
Why are you moving the axle forward?
PhilD is offline
post #4 of 13 Old 09-14-2010, 08:03 PM
Mall Krawler's Avatar
We tried to push the front axle forward over 1.5", but the front coil springs were not happy. We had to shorten the arms and only push it 1" forward. That is about all you can get with out moving your spring mounts. The stock driveshaft was fine, they have alot of extra play in them. If you have an aftermarket drive shaft you may have some issues. I tried to replace mine with a Je Reel and it was not long enough, so Tom woods made me a custom length one.
Mall Krawler is offline
post #5 of 13 Old 09-14-2010, 09:34 PM
SoK66's Avatar
Teraflex's full flexarm suspension extends the front about 1" vs stock. It's because of their rather odd front spring design which uses an offset upper spring seating coil. This tilts the spring rearward on the right side, and forward on the left. This unfortunately causes the end of the sway bar (and TF's links) to hit the LF spring. if you try to shorten the control arms to eliminate the contact the springs start to bow badly. It does ride and flex ok, but it's a PITA to stop the sway bar to spring interference. I ended up using Poly's links to raise the bar enough to eliminate it.
SoK66 is offline
post #6 of 13 Old 09-14-2010, 11:40 PM Thread Starter
i going to move the sway bar forward. New drive shafts are a must as is the new control arms all which i know about my major concern is the steering box at this stage.
I am moving the diff forward to gain more approach agle
DaveJK is offline
post #7 of 13 Old 09-14-2010, 11:56 PM
VKS Fab
JK Vick's Avatar
Chop the frame horns and throw on a PS BFH bumper and call'er done. My 2cent
JK Vick is offline
post #8 of 13 Old 09-15-2010, 08:22 AM
TrailDuty.com
PhilD's Avatar
X2 A much simpler solution that works well. Bodyguy did this using his own bumper and he's got a great approach angle
PhilD is offline
post #9 of 13 Old 09-16-2010, 07:33 AM
Liquor's Avatar
that looks great
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #10 of 13 Old 09-16-2010, 08:51 AM
garner's Avatar
That is what I did and it works like a champ!
2008 Rubicon Unlimited | Rescue Green | OME Long Travel HD Lift | Raceline Monster Beadlocks | 39.5 Irok Bias Tires| 5.13 Gears | PSC BFH Front Bumper | PSC Flares | PCS Crusher Corners |PSC Rock Brawler Rear w/tire carrier | Warn 9.5ti | ARB High Flow On Board Air | sPOD |Rock Hard Sport Cage | Poly High Steer Kit | Poly Front Track Bar Brace | Alloy Chromoly Rear Axle Shafts
garner is offline
post #11 of 13 Old 09-16-2010, 10:26 AM
TrailDuty.com
PhilD's Avatar
Originally Posted by Liquor View Post
that looks great
Yeah, less is more when it comes to wheeling. There's many things I'd have done different in retrospect...
PhilD is offline
post #12 of 13 Old 09-16-2010, 05:59 PM Thread Starter
doing this would cause some problems over here in australia i would have to have a engineer look at this we aren't allowed to cut any part of the chassis. we can cut mounts off etc but they require a engineer inspection
DaveJK is offline
post #13 of 13 Old 09-16-2010, 06:44 PM
2k2wranglerx's Avatar
i bet you're going to run into steering issues as well
2k2wranglerx is offline
