Valve Stem Help/tire pressure monitor - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 09-13-2010, 06:13 PM Thread Starter
gakmrk's Avatar
Need some advise. I bough new wheels and tires and I am ready to swap them out with the OEM wheels. Do I need to use the valve from the OEM wheels for the tire pressure monitor and will it work with the new wheels?
gakmrk is offline
post #2 of 10 Old 09-13-2010, 06:20 PM
StubEXrube's Avatar
They will work with the new wheels.
You don't have to use them however- if you use regular stems in place of the TPMS, then you will have a constant light on the dash, and it will chime 4x every time that you start the vehicle. It is actually very easy to get used to. It doesn't chime when you are driving. It will not effect any engine/ ECU performance either. It's safe to remove them as long as you keep an eye on your tire pressure from time to time.
You can also get a programmer like the AEV Procal unit for around $140. It allows you to keep the TPMS stems, while you set a lower psi (or get rid of them). This way you can run whatever pressure that you want with no chime/ light.
StubEXrube is offline
post #3 of 10 Old 09-13-2010, 06:33 PM Thread Starter
gakmrk's Avatar
Thanks for the quick reply. I was going to get the AEV Procal unit to recal the speedometer.
Do you run with or without the TPMS?
gakmrk is offline
post #4 of 10 Old 09-13-2010, 06:41 PM
StubEXrube's Avatar
Over 3 years now- without. I don't mind the chime at start up, and the light is not very annoying either (since it's not a 'check engine' light or anything like that).
Reason I don't care for them is that if you do run them and air-down on the trail, they are more prone to damage- and can be expensive to replace. I also have found in other vehicles that they are not always accurate 100% of the time. I would rather just check my psi from time to time.
post #5 of 10 Old 09-13-2010, 07:09 PM
BenFoo's Avatar
if your state has a safty inspection (stupid PA) it wont pass if that light is illuminated.
BenFoo is offline
post #6 of 10 Old 09-13-2010, 07:16 PM Thread Starter
gakmrk's Avatar
No inspections in FL. I was wondering if it is worth the time and money to make the switch. It will cost me around $40 to have a shop pull the old ones annd replace them with new ones. I don't want it to be an issue when I sell the OEM Sahara wheels.
gakmrk is offline
post #7 of 10 Old 09-13-2010, 08:26 PM
BenFoo's Avatar
I havnt run them on my past 2 wheel/tire sets and I dont plan to in the future. For me they just caused problems. Falsely illuminating the warning light several times. They dont fair to well if you rub one agasint a rock either...
BenFoo is offline
post #8 of 10 Old 09-13-2010, 08:52 PM Thread Starter
gakmrk's Avatar
how did you get the warning light to turn off w/o the TPMS?
gakmrk is offline
post #9 of 10 Old 09-13-2010, 10:59 PM
BenFoo's Avatar
you can disable it using a superchips or aev procal.
BenFoo is offline
post #10 of 10 Old 09-13-2010, 11:10 PM
gold knight's Avatar
Like Stub said after 1 1/2 years it's no big deal... you kind of get used to it. And when you get that Procal you can set the threshold to zero and no more light.
gold knight is offline
