Gear Help PLEASE. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 09-12-2010, 08:32 AM Thread Starter
Gear Help PLEASE.
Just picked up a 2011 JK unlimited sport, manual trans.
Going to be installing a RK 3.5 mid arm lift, and 35x12.5 tires.
I want to install 4.88 gears. The current gears are 3.21's.
Dana 30 front.
Dana 44 rear.
I don't know what I need to order. Do I need different carriers, spider gears, bearings, etc. Ive been searching to no avail. If I need different carriers where do I get them. Ive been searching for hours and cant find anything, except for ring and pinions.
Any help would be greatly appreciated, part #'s to everything I need would be AWESOME.
2011jk is offline
post #2 of 4 Old 09-12-2010, 09:07 AM
If you're keeping it open, you're going to need a high ratio open carrier for the D30.
Other than that, since you're bearings are new, and you can remove them without destroying the bearing cage, all you need to order is 4.88s front/rear w/ install kits.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #3 of 4 Old 09-12-2010, 09:29 AM Thread Starter
Thanks. I will be keeping it open for now. Any idea where I can get the carrier at.
2011jk is offline
post #4 of 4 Old 09-12-2010, 03:42 PM
2k2wranglerx's Avatar
i'd order a full install kit for the front. that's a lot hanging on you not nubbing up the bearings when you pull them...
i don't know if they still do it, but 4wd hardware sells G2 gears/full install kits/ with G2 covers for 550 shipped to your door.
that gives you every bearing, every seal, etc. seems like a helluva good deal to me.
i've installed them on jeepnick's jeep and on my wife's jeep. it was super smooth.
2k2wranglerx is offline
