Spare Tire carrier, mounted on the inside? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 09-11-2010, 06:44 PM Thread Starter
Iron's Avatar
Well, living in a city that refused to fix pot holes it took just two years for the 34' tire on the factory tire carrier to make the factory hinges sag and the welds start to pop (btw: the factory tail gate hinges are only rated to 50lbs)
So I replaced them with a SWAG Offroad drop down tail gate, now the question was where to mount the spare? The cheapest after market tire carrier, up here in canada runs around $700 with a bumper system your looking at $1400+. So after toying with the idea of a Gen-right carrier I decided to make my own, but carry the spare Inside.
This requries the removal of the rear seats, but since I took those out 2 day after buying the Jeep that isn't an issue for me.
Made up a bracket at work out of 3/8" thick flat bar, 6" wide 32" long, laser cut a slot in the center and a bolt hole pattern at one end. Using six 1/2" grade 8 bolts I mounted it to the tub behind the drivers seat (see photo) using fender washers on the outside, I drilled 1" holes on the inner fender well to make it faster to do up the bolts, I didn't feel like taking the inner well off.
Then using some 5/8" redie rod and a alloy plate I mounted the tire using the center slot in the plate. the slot is 6" long so you can use it on tires ranging from 30" to 37" tall. I still have full access to the tiny storage compartment in hte back, the rear ward view is not affected at all, and the weight of the tire is on the drivers side so it some what counters the weight of the gas tank.
Mike B
08' Jeep Wrangler
08' Dodge Avenger SXT (winter beater)
64' Plymouth Sport Fury(sold)
58' Triumph TR-3A(in 1,000,000 pieces)
Iron is offline
post #2 of 22 Old 09-11-2010, 06:45 PM Thread Starter
Iron's Avatar
Like I mentioned the re-view is not effected at all and the cargo area is still usable unlike if you were to lay the tire down. The tire stands up with the weight of the tire on the cargo floor, (the piece of wood was just to clear one of the brackets for the seat, didn't want it to rub on the tire)
Total cost, if I had to pay for it less than $40, but since I did the majority at work it was a freebie!!! Yeah I know I suck!
Mike B
08' Jeep Wrangler
Iron is offline
post #3 of 22 Old 09-11-2010, 06:50 PM
e-jeep's Avatar
Feedback: 12 reviews
GENIUS!!! ...very creative. Nice work.
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #4 of 22 Old 09-11-2010, 06:53 PM
Ron R's Avatar
H2 style, I like it.
Although I would suggest removing that vent cover you put on the tail gate. Since you're running a hard top, if the air bag deploys the pressure will bust your ear drums if there is no way for air to exit the cab.
Ron R is offline
post #5 of 22 Old 09-11-2010, 06:58 PM
SlvrJK's Avatar
Very cool. I've been thinking about doing something similar for when I go bigger. The only thing that concerns me with that setup is the amount of leverage being placed on the inner fender well by the weight of the tire. I don't know how thick the sheetmetal is there, but it could be reasonably thick and I'm sure you though about that. I'm defitely glad to see there is still plenty of usable floor space back there and that rearward visibility is still good, gives me a reason to think about a similar tire mount. Thanks for sharing.
SlvrJK is offline
post #6 of 22 Old 09-11-2010, 09:51 PM Thread Starter
Iron's Avatar
No worries there, the Swag kit vents the cover, the two plates are spaced apart from each other and from the tail gate, plenty of room for air to move freely back there.
looks like the wheel arch where I mounted it was double walled, so it should be strong enough, and with the fender washer spreading the weight around I don't see any issues ahead, and if there are I can simply brace the bottom with an l bracket and tie it in with the floor. Yes already thought that one thru
Mike B
08' Jeep Wrangler
Iron is offline
post #7 of 22 Old 09-11-2010, 11:29 PM
BadAssJK's Avatar
Nice.
BadAssJK is offline
post #8 of 22 Old 09-12-2010, 05:48 AM
bonecollector's Avatar
Nice idea but Jerry my pit would have a hard time rideing back there and not marking the spare ( tires are open game for him) Ron R, allways wondered about the tgate vent Dam hard to clost the doors on a htop.
bonecollector is offline
post #9 of 22 Old 09-12-2010, 06:33 AM
RobertJK's Avatar
Did similar to my unlimited. Had to keep the small seat folded down. I dont have good pictures will try and take some better ones soon. I used the roll bar as a mounting point though.
Robert
RobertJK is offline
post #10 of 22 Old 09-12-2010, 09:12 AM
desert dog's Avatar
I'm toying with something similar, but planning to run a bar across the roll bars and attaching the tire to that, and anchor points to put a ratchet strap around the tread for extra security in a roll-over. My 37" swamper fits easily in that area.
desert dog is offline
post #11 of 22 Old 09-12-2010, 09:21 AM Thread Starter
Iron's Avatar
Thought about the rollbar tie in but went with the plate as I didn't want to mess with the rollbar. And I have plans for a ratchet strap around the tire there are two loops on the floor where the rear seat sat that are perfect for the strap.
Mike B
08' Jeep Wrangler
Iron is offline
post #12 of 22 Old 09-12-2010, 09:43 AM
BadAssJK's Avatar
SuffolkJK did just that on his 2 door for his 35s. Came out pretty nice as well.
BadAssJK is offline
post #13 of 22 Old 09-12-2010, 09:44 AM
haha brings back memories of my grand cherokee
BBirish is offline
post #14 of 22 Old 09-12-2010, 10:24 AM
TheBeatenPath's Avatar
if your in a 2dr you could go to tractor supply and buy one of the tractor seats
figure out a way to mount it there and then you can carry another person if need be
john deere ones are yellow for you yellow jeepers
TheBeatenPath is offline
post #15 of 22 Old 09-12-2010, 12:42 PM
tkob1060's Avatar
looks good except those washers look pretty darn small. I'd get bigger ones or maybe make a plate and have all the bolts come through it for the outside of the fender. You dont want that thing breaking loose in an accident.
tkob1060 is offline
post #16 of 22 Old 09-12-2010, 12:56 PM
e-jeep's Avatar
Pics????
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #17 of 22 Old 09-12-2010, 06:58 PM
e-jeep's Avatar
This made me wonder ...would the Springtail MPAC side rack accomplish the same?
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #18 of 22 Old 09-12-2010, 09:01 PM
fourplyn's Avatar
great idea.!
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #19 of 22 Old 09-13-2010, 05:53 AM
This is the route I took. Can't really mounted sideways due to the truck box, but it works great.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #20 of 22 Old 09-13-2010, 06:42 AM
e-jeep's Avatar
Very cool ...thanks.
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #21 of 22 Old 09-13-2010, 01:30 PM
e-jeep's Avatar
Originally Posted by fourplyn View Post
great idea.!
Got an e-mail back from Springtail ...
"That is a tough question...my 33s on steelies weigh over 100 pounds. I know the rack will hold up to the weight but I am not sure about the JK sheetmetal...I would worry that constant rocking from offroading would eventually stress the sheetmetal to breaking point.
I think that a tire/wheel that heavy belongs on a swing away or a baja style bed mount.
Doc"
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #22 of 22 Old 09-13-2010, 03:35 PM
fishinmagician's Avatar
And My S-10 blazer
fishinmagician is offline
