Currie CA's wont take grease - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 09-11-2010, 02:11 PM Thread Starter
voodoojk's Avatar
OK. I have front Currie lower CA's and the front johnny joint will not take grease. I pump it and and it spits it all back out through the zerk. (hehehehehe) I've done every thing i know to try and clean the the joint out short of taking it entirely apart ( which i dont personally have the tools to do) they are not that old and not abused and super clean.
Any tips or tricks short of rebuilding the joint would be appreciated.
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
Tom Woods Shafts F&R
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Buschwacker Flat Flares
Poly Tie Rod
JKS Disco
voodoojk is offline
post #2 of 8 Old 09-11-2010, 02:19 PM
RIP Brad
abendx's Avatar
Maybe try replacing the zerk?
abendx is offline
post #3 of 8 Old 09-11-2010, 02:22 PM Thread Starter
voodoojk's Avatar
zerks are brand new. The grease flows through the zerk just fine. im puzzled but the more i google this issue its a pretty common problem...d'oh!
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
voodoojk is offline
post #4 of 8 Old 09-11-2010, 03:22 PM
Slow and Low
Co4Lo's Avatar
Uh... maybe it's already full of grease?
Co4Lo is offline
post #5 of 8 Old 09-11-2010, 05:38 PM Thread Starter
voodoojk's Avatar
well turning the joint they are as dry as a camel fart in a sand storm. I never had them take grease since i bought them so unless they are full from the factory. idk.. I had one of the 4 joints take grease and it oozed out of the spring clip instead of the actuall joint. thought that was odd.
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
voodoojk is offline
post #6 of 8 Old 09-11-2010, 06:35 PM
Slow and Low
Co4Lo's Avatar
The joints are really tight. They don't really have much room in them to hold much grease. I've had the 3" Johny Joints on a rig and had the same issue.
Rock Krawler used to put grease fittings in theirs too, but now they just put a cap screw in them and call it a service port. They recommend that you just put a few drops of 3 in 1 oil in the service port to maintain them.
I've been oiling the port once in a while and I spray some teflon lube on the exposed ball after I clean them. Seems to work great!
Co4Lo is offline
post #7 of 8 Old 09-11-2010, 07:00 PM
Mine squirt out the sides after after about two or three pumps from one of the smaller mini style grease guns.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #8 of 8 Old 09-11-2010, 07:07 PM
Openly Hostile
As said, there is not a lot of room for grease, a pump or two a year.
Jason
SDMF is offline
